Topic: C++ Programming HELP (Read 2051 times) previous topic - next topic
Ringle92
Im looking for someone familiar with Arduinos and C++ Programming.
I need a program that would open and close a door using a keyfob or pushbutton.
It will be sending a signal to my driver which is a Gecko Drive which will control my servo motor.
At 0 degrees the door will be fully open and at 87 degrees the door will be partially (not quite all the way)
closed.  Also if there is a resistance someone gets caught in the door if possible would like it to open up.  Does this sound like someting someone could help me with?
retrolefty
Not clear. You need someone to help you learn C++ programming or someone to write you a sketch to perform what you stated?
Lefty
