Topic: LCD4BIT problems on Arduino 1.0 (Read 12211 times) previous topic - next topic
ogogon
Good evening, colleagues!
After upgrading to the IDE Arduino 1.0, I no longer compile the program to work with the LCD display.
I am using shield with an 1602 LCD display and five buttons like this here - http://www.geeetech.com/arduino-lcd-1602-keypad-shield-p-251.html
I am using Arduino IDE 1.0 for Mac OS X.
I'm downloading the library, and then unpack it and copy in the directory '/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/'.
After starting, IDE is find the library and loads of examples from it.
If you try to compile the sample LCD4Bit_modExample.pde I get the following diagnosis:
Quote
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:29:57: error: WConstants.h: No such file or directory
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::pulseEnablePin()':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:58: error: 'LOW' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:58: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:59: error: 'delayMicroseconds' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:61: error: 'HIGH' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:64: error: 'delay' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::pushNibble(int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:73: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::commandWriteNibble(int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:99: error: 'LOW' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:99: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::commandWrite(int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:106: error: 'LOW' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:106: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::print(int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:118: error: 'HIGH' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:118: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:119: error: 'LOW' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::clear()':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:139: error: 'delay' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::init()':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:146: error: 'OUTPUT' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:146: error: 'pinMode' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:154: error: 'delay' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:160: error: 'delayMicroseconds' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::leftScroll(int, int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:225: error: 'delay' was not declared in this scope
All forums are advised to replace on file LCD4Bit_mod.cpp the line '#include "WConstants.h" on "#include "Arduino.h"'.
Alas, this does not lead to success.
It turns out that's what:
Quote
In file included from /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:191,
                 from /Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:29:
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:116: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, const char*)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:115: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, const String&)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:117: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, char)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:116: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, const char*)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:118: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, unsigned char)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:117: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, char)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:119: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:118: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, unsigned char)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:120: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, unsigned int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:119: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, int)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:121: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, long int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:120: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, unsigned int)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:122: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, long unsigned int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:121: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, long int)' here
In file included from /Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:29:
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:195: error: declaration of C function 'uint16_t makeWord(byte, byte)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:194: error: previous declaration 'uint16_t makeWord(uint16_t)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:205: error: declaration of C function 'long int random(long int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/stdlib.h:504: error: previous declaration 'long int random()' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:206: error: declaration of C function 'long int random(long int, long int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:205: error: previous declaration 'long int random(long int)' here
How can I overcome this problem?
Ogogon.
Jaiabercrombie
i have had the same troubles.  i went back to 0.23 and use that.  the problem being the developer of the board needs to redo the library.
ilya_dan
BTW, standard LiquidCrystal library provide 4-bit support since ArduinoIDE 0016.
So, there are no reasons to use old LCD4BIT code except unless you avoid changing the sketch for some reason. The better choise is to spend little time to transition from this unsupported library to LiquidCrystal (that is a part of Arduino IDE distro).
Krodal
I agree with Ilya V. Danilov above this message.
What happened is that the download code is not compatible with Arduino 1.0.
If it was just a sketch, removing the includes from the source would probably be enough.
But since you use it as a library, the includes have to be according to Arduino 1.0.
pluggy
Dump that gawd-awful LCD4bit library.  The standard LiquidCrystal library is vastly superior.  The developer probably gave up on it once the standard library did 4 bits (and better) years ago. I've been playing with Arduino for around 3 & a half years and the standard LiquidCrystal library has done 4 bits for most of that time.
http://pluggy.is-a-geek.com/index.html
magnusvr
Found a solution!
This works with Arduino 1.0.1 and the 2x16 LCD/keypad.
http://www.dfrobot.com/wiki/index.php?title=Arduino_LCD_KeyPad_Shield_(SKU:_DFR0009)
Look at the second example, using LiquidCrystal.h
I just pasted the code, and added
#include <LiquidCrystal.h>
at the top, and "tadaaaa"!
KR
Magnus
Jovik
If you're using "1602 LCD and 6 AD buttons" shield from ITeadStudio, then you need to change default pins. Below code works for me :)
from
Code: [Select]
// include the library code:
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
p0lak0
I´m using the Arduino 1.0.3.
I downloaded the library in: C:\Program Files (x86)\arduino-1.0.3\libraries\LCD4Bit_mod
In file LCD4Bit_mod.cpp I modified:
#include "LCD4Bit_mod.h"
extern "C" {
  #include <stdio.h>  //not needed yet
  #include <string.h> //needed for strlen()
  #include <inttypes.h>
//  #include "WConstants.h"  //all things wiring / arduino
and...It works fine.
LilKS
extern "C" {
Tested it on Mac OSX, Arduino 1.0.4, and it worked fine.
Also tested this (from http://www.dfrobot.com/wiki/index.php/Arduino_LCD_KeyPad_Shield_%28SKU:_DFR0009%29) and it worked too:
Code: [Select]
//Sample using LiquidCrystal library
This program will test the LCD panel and the buttons
Mark Bramwell, July 2010
// select the pins used on the LCD panel
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(0);      // read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
if (adc_key_in < 50)   return btnRIGHT;
if (adc_key_in < 195)  return btnUP;
if (adc_key_in < 380)  return btnDOWN;
if (adc_key_in < 555)  return btnLEFT;
if (adc_key_in < 790)  return btnSELECT;
return btnNONE;  // when all others fail, return this...
lcd.begin(16, 2);              // start the library
lcd.setCursor(0,0);
lcd.print("Push the buttons"); // print a simple message
lcd.setCursor(9,1);            // move cursor to second line "1" and 9 spaces over
lcd.print(millis()/1000);      // display seconds elapsed since power-up
lcd.setCursor(0,1);            // move to the begining of the second line
lcd_key = read_LCD_buttons();  // read the buttons
switch (lcd_key)               // depending on which button was pushed, we perform an action
   case btnRIGHT:
     lcd.print("RIGHT ");
   case btnLEFT:
     lcd.print("LEFT   ");
   case btnUP:
     lcd.print("UP    ");
   case btnDOWN:
     lcd.print("DOWN  ");
   case btnSELECT:
     lcd.print("SELECT");
     case btnNONE:
     lcd.print("NONE  ");
If you still have a problem displaying info on the screen, be sure to check the LCD contrast!
