Loading...
Pages: [1]   Go Down
Author Topic: Arduino Due Clock output  (Read 844 times)
Offline Offline
Newbie
View Profile
Does anybody know how to generate a clock signal on an digital pin of an Arduino Due?
like a CPU clock. I am trying to communicate to a OV3640 but i have to give it a 24 MHz clock signal. I was wondering if there was a way to generate that using the CPU clock of the Due.
Logged
The Netherlands
Offline Offline
Jr. Member
MKDS hacker and Programmer
View Profile
I don't think that it is possible using the CPU clock, but you could maybe use a pwm signal. Or a timer interrupt.
Logged
Subscribe my youtube channel: http://www.youtube.com/user/MKDS3
Offline Offline
Newbie
View Profile
i tried using the PWM signal but i could not adjust the frequency. Do you know how to change it?
Logged
The Netherlands
Offline Offline
Jr. Member
View Profile
I don't exactly know, but you should definitely take a look at this: http://asf.atmel.com/docs/latest/sam3x/html/group__sam__drivers__pwm__group.html
Logged
Offline Offline
Newbie
View Profile
Thanks a lot! I am going to try that.
Logged
Offline Offline
Newbie
View Profile
I finally found out that this:
cannot work for me because am using the Arduino IDE. Do you know of anything else? Everything i tried cannot go above 150kHz frequency.
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
The SAM processor has 3 programmable clock pins but the function is not supported by Arduino.
From the data sheet
Quote
The PMC controls 3 signals to be output on external pins, PCKx. Each signal can be independently
programmed via the Programmable Clock Registers (PMC_PCKx).
PCKx can be independently selected between the Slow Clock (SLCK), the Main Clock
(MAINCK), the PLLA Clock (PLLACK), UTMI PLL Clock (UPLLCK/2) and the Master Clock
(MCK) by writing the CSS field in PMC_PCKx. Each output signal can also be divided by a
power of 2 between 1 and 64 by writing the PRES (Prescaler) field in PMC_PCKx.
I've not used them though so can't advise on that. They may not even be broken out on the Due.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Newbie
View Profile
Any example code of setting that up?
Logged
Offline Offline
Tesla Member
View Profile
WWW
Sorry, I've not worked with this yet.
______
Rob
Logged
Pages: [1]   Go Up
Print
Jump to:
