Topic: Just struggling with this, any pointers would be welcome (Read 1 time) previous topic - next topic
ijm51000
I have looked at this and can't see the wood for the trees!
I am use in Arduino 1.03 and in my program I use
string.replace("T", "");
and it does delete the character, however I need to do this for a few fixed characters and therefore trying to place it in a function , the Serial.print does correctly print the characters to be replaced and is there as a debug statement.
//declared at the top of program
const char stripChars [6] PROGMEM = "{}DIT";
//Sanity call to function
String striped = stripMyStr("{A}AIATADA");
//function
String stripMyStr(String strToStrip){
         for (int i = 0; i < 5; ++i)
              {    //tried uint8_t myChar
                     myChar = pgm_read_byte (stripChars + i);
                     Serial.print(myChar);
                     strToStrip.replace(myChar, "");
         return strToStrip;
Error message from Arduino IDE is :-
error: call of overloaded 'replace(uint8_t&, const char [1])' is ambiguous
Any help much appreciated, explanation as to where I am going wrong(plain English :-) very, very welcome.
Ian
guix
Hello,
I suggest you just forget the String class and use standard C strings :)
ijm51000
Though I do agree and as such the program does work without this function, but for once in my life I have time to solve the problem the way I wish, not just take an easy way, or put it another way, retired and being pedantic :-)
guix
There are some bugs in the String class, that's why I recommend not using it.
Anyway, your problem is that "myChar" is (most likely) declared as "char myChar", and that replace function expect a String, so you have to convert. I'm not sure, but try:
Code: [Select]
strToStrip.replace( (String) myChar, "");
nickgammon
Code: [Select]
sketch_mar16a.ino: In function 'String stripMyStr(String)':
sketch_mar16a:15: error: call of overloaded 'replace(char&, const char [1])' is ambiguous
/Applications/Arduino_1.0.4.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:164: note: candidates are: void String::replace(char, char) <near match>
/Applications/Arduino_1.0.4.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:165: note:                 void String::replace(const String&, const String&) <near match>
The error message is basically telling you what you need. This compiles:
Code: [Select]
//function
    char myChar = pgm_read_byte (stripChars + i);
    strToStrip.replace(String (myChar), "");
  return strToStrip;
void setup ()
  Serial.begin (115200);
  Serial.print (stripMyStr ("{A}AIATADA"));
}  // end of setup
void loop () { }
Please note that in versions of the IDE up to and including 1.0.3, the String library has bugs as discussed here and here.
In particular, the dynamic memory allocation used by the String class may fail and cause random crashes.
I recommend reworking your code to manage without String. Use C-style strings instead (strcpy, strcat, strcmp, etc.), as described here for example.
Alternatively, install the fix described here:  Fixing String Crashes
Preferably upgrade your IDE to version 1.0.4 or above at: http://arduino.cc/en/Main/Software
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Code: [Select]
I don't think it is a particularly good idea to call things in the constructor, particularly if you are doing serial prints, as you were. The constructor is called before the system is fully initialized.
ijm51000
Take a Gold Star!
I had tried casting the variable but further up and probably got it wrong, also bowled myself a googly by replacing
strToStrip.replace((String) myChar, "");
with
strToStrip.replace( myChar, 0x00);
which compiled and of course caused havoc.
Many, Many Thanks
Ian
michinyon
Does the alleged  replace()  method of the string class you are trying to use,   accept a null string
or empty string as an argument ?
michinyon
Code: [Select]
I've only used the PROGMEN method a few times,   so I am not an expert,  but when I
was using it the other day and looked up the example,  they were telling me to use
Code: [Select]
prog_char   message[] PROGMEM = "this is the message" ;
So if you are using regular 'char' instead of 'prog_char',  that might be your problem.
