Topic: Leonardo and critical timing (Read 545 times) previous topic - next topic
tim7
Dear Group,
I'm designing a device which will use a USB port to upload firmware updates (the port won't be used for anything else).  To save space I'm planning on using a Sparkfun ProMicro, which is an ATmega32U4 board similar to an Arduino Leonardo.
As far as I can see I have two choices for firmware upload:
- An AVR109 bootloader, which requires hardware signals to enter programming mode
- The Leonardo environment, which includes USB code in the application to trigger the bootloader
The second option is simpler and more elegant, but may interfere with the application code.  The application contains certain routines which run with critical timing, which might be disturbed if interrupted by USB service routines.
Does anybody have any advice or pointers regarding the Leonardo application-space USB code?  Can it be disabled and re-enabled in software?  Thanks,
Erdin
If you don't use the Mouse.begin() or the Keyboard.begin(), they are not enabled.
http://arduino.cc/en/Reference/MouseKeyboard
However, the Leonarde detects a low baudrate of 1200, it is used to upload a new sketch.
http://arduino.cc/en/Guide/ArduinoLeonardo
