Topic: 10uF where to put it confused? (Read 934 times) previous topic - next topic
silverfox0786
Hi im confused as to where I put the 10uF Cap on an UNO
do I put it on an UNO that needs to be programmed or
on the UNO that is acting as the programmer
this is the statement that confuses me
Code: [Select]
5.Wire your Arduino board to the target as shown in the diagram below. (Note for the Arduino Uno: you'll need to add a 10 uF capacitor between reset and ground.)
original link
http://arduino.cc/en/Tutorial/ArduinoISP
Nick Gammon
The one acting as a programmer.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
silverfox0786
Thanks for the answer.
only thing now is that raises 1 more question please
seeing as the "programmer" uses pin 10 as its Reset line
do I attach the cap from True Reset line (pin1) to Ground
or Pin10 to Ground
Nick Gammon
True reset. You are trying to stop the programmer being reset when the sketch is uploaded through it.
More info:
sonnyyu
Sorry, Nick is typing faster than my copy and paste.  :)
silverfox0786
thanks nick for the explanation and thanks sonyyu for the picture
both put together make everything so much more clearer
much appreciated
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
