Topic: How to apply ADMUX fuction to a multi analog inputs system (Read 3373 times) previous topic - next topic
KusanagiMotoko
Greeting all, (and sorry about my poor English)
I was doing my project until got stuck by ADC. I'm new to Arduino so some of my questions may look quite silly to you guys, but please help.
The purpose of this un-finished code is to firstly handle the analog input from pin A0, A2 and A1 as an interrupt, then convert both of them into digital signals by using ADMUX, and then pass them to FFT execute module.
Question 1: Do I need to import the AVR library if I'm going to use some AVR variables and methods? How about stdint library?
             2: How do I make the ADMUX handle two or more analog inputs? I have looked up thishttp://openenergymonitor.blogspot.com.au/2012/08/low-level-adc-control-admux.html, but still don't know how to implement ADMUX such that it can "catch" two or more analog inputs simultaneously (doable?).
Here is the relative code:
Code: [Select]
// free running ADC mode, f = ( 16MHz / prescaler 64 ) / 13 cycles per conversion = 19`231 Hz
  ADMUX = _BV(REFS0) | eva_OUTA; //| eva_OUTB; how to make it take other input?
  ADCSRA = _BV(ADSC) | _BV(ADEN) | _BV(ADATE) | _BV(ADIE) | _BV(ADPS2) | _BV(ADPS1); // | _BV(ADPS0);
And if it helps, here is the full un-finished code.
Code: [Select]
#include <LiquidCrystal.h>
#include <ffft.h>
#include <stdint.h>      //Necessary?
#include <avr/interrupt.h>
//LCD pin connection:
#define LCD_D4 5
#define LCD_D5 4
#define LCD_D6 1
#define LCD_D7 0
#define LCD_RS 12
#define LCD_En 11
//Evaluation board pin connection:
#define eva_OUTA A0
#define eva_OUTB A2
#define eva_OUTN A1
#define eva_TEMP A5
//Interrupt buttons connection with condition:
#define flip_page_button 0
#define reset_button 1
volatile int FP = HIGH; // active low
volatile int Reset = HIGH;
//Battery condition monitor connection:
#define bat A4
float Temp;
//initialize the lcd lib and interface pins:
LiquidCrystal lcd(LCD_RS, LCD_En, LCD_D4, LCD_D5, LCD_D6, LCD_D7);
/////////////////////////////////Signal capture using interrupt
volatile  byte  position = 0;
volatile  long  zero = 0;
int16_t capture[FFT_N];                //Pre-locate wave aptureing buffer
complex_t bfly_buff[FFT_N];            // FFT buffer
uint16_t spektrum[FFT_N/2];            // Spectrum output buffer
// free running ADC fills capture buffer
ISR(ADC_vect)
  if (position >= FFT_N)
    return;
  capture[position] = ADC + zero;
  if (capture[position] == -1 || capture[position] == 1)
    capture[position] = 0;
  position++;
///////////////////////////////////////////setup program:
  /* Make sure all pins are put in high impedence state and
   that their registers are set as low before doing anything.
   This puts the board in a known (and harmless) state */
  for (int i=0;i<20;i++) {
    pinMode(i,INPUT);
    digitalWrite(i,0);
  /* initialize serial */
  //pinMode(4, OUTPUT);
  //Serial.begin(115200);
  Temp=0.0; //initiate teamperature value
  ////////////////////////////Welcome LCD ///////////////////////////////
  //set up LCD's number of columns and rows:
  lcd.begin(16,2);
  //print welcome line
  lcd.setCursor(0,0); //write in the first line
  lcd.autoscroll();
  lcd.print("***** System");
  lcd.noAutoscroll();
  lcd.setCursor(0,1); //write in the second line
  lcd.autoscroll();
  lcd.print("*******");
  lcd.noAutoscroll();
  ///////////////////////////////////End welcome LCD //////////////////////
  sei(); //enable global interrupts for ADC and Pushbuttons
  ///////Button Interrupt////////////////////
  attachInterrupt(flip_page_button, FLIPPAGE, CHANGE);
  attachInterrupt(reset_button, RESET, CHANGE);
  ////////////////////////Signal input handling/////////////////////////
  // ADC channel to capture
  //ADC channel: OUT_A
  //After read OUT_A, start read OUT_B and OUT_N HOPEFULLY
  ADMUX = _BV(REFS0) | eva_OUTA //| eva_OUTB;
  //Serial.println("Start to calc zero");
  long midl = 0;
  // get 2 meashurment at 2 sec
  // on ADC input must be NO SIGNAL!!!
  for (byte i = 0; i < 2; i++)
    position = 0;
    delay(100);
    midl += capture[0];
    delay(900);
  zero = -midl/2;
  //Serial.println("Done.");
  //Temperature:
  float Temp1 = analogRead(eva_TEMP);
  float Temp2 = Temp1/204.8;
  Temp = (Temp2-570)/2;
  //location on display ???
  //lcd. print(Temp);
  //Button Interupt:
  interrupts();
  //////////////////////signal input
  if (position == FFT_N)
    fft_input(capture, bfly_buff);
    fft_execute(bfly_buff);
    fft_output(bfly_buff, spektrum);
    //peak locate function here
    // Do work
    position = 0;
void FLIPPAGE(){
//Flippage pushbutton working function here
void RESET(){
//Reset pushbutton working function here
Any suggestion will be appreciated. Again, thank you guys.
johnwasser
There is only one A/D converter with a multiplexer (ADMUX) to select which pin is connected to the input of the A/D converter.  You can't catch two analog signals simultaneously.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
CrossRoads
You can add an external ADC that can sample multiple signals simultaneously.
They do cost more.
You will likely find that catching 4 samples sequentially will be fast enough tho.
KusanagiMotoko
They do cost more.
Can you please guide me how to implement an external ADC? Since this is a FFT operation so I want to make sure the time slot for all signals is the same. So I can't use a simple Analogread().
CrossRoads
#4
Mar 16, 2013, 05:19 am Last Edit: Mar 16, 2013, 05:33 am by CrossRoads Reason: 1
You connect one up, you read it via SPI commands.
http://ww1.microchip.com/downloads/en/DeviceDoc/21298e.pdf
Here's the way I read 8 inputs & sent it out via serial.
You'll have to write up all the declarations & stuff.
Code: [Select]
Every 5mS, read a Pot via SPI, send it via RS232 .
void loop(){
 if (millis()>=previousMillis){
  previousMillis = previousMillis + 5; // set for next 5 mS interval
  // read ADC with 3 byte transfer
  PORTB = PORTB & B11111011;  // ADC_SS, LOW
  // ADCaddress = 0x0600, 640, 680, 6C0, 700, 740, 780, 7C0
  dummyADC = SPI.transfer (highByte(ADCaddress));  // 0x06, 0x07 out, read in dummy data
  highADC = SPI.transfer (lowByte(ADCaddress));    // 0x00, 0x40, 0x80, 0xC0, read in upper 4 bits
  lowADC = SPI.transfer (0);              // dummy 0 byte out , read in lower 8 bits
  PORTB = PORTB | B00000100; // ADC_SS, HIGH
  Serial.write (ADCsyncbyte);      // syncbyte = B00110011, 0x33
  Serial.write (address_count);    // find way to put this in top nibble of next command?
  Serial.write (highADC & 0x0F);   // send it out
  Serial.write (lowADC);           // send it out
  address_count = address_count +1;  // 0 to 7, pass to Rx for DAC sync - how?
  ADCaddress = ADCaddress + (address_count * 0x40); // update for next pass
  if (address_count == 8){
  address_count = 0;
  }  // reset if hit all 8
  } // end 5mS test
