Loading...
Pages: [1]   Go Down
Author Topic: How do I add i2c lcd arduino library, ask for an explanation  (Read 200 times)
Offline Offline
Newbie
View Profile
Help me, how to add a library to the arduino, I want to add i2c lcd library
Logged
Dee Why NSW
Offline Offline
God Member
View Profile
I believe there is some specific instruction on this on the Arduino website, but I just put it with all the other libraries. This is in a folder under the 1.0.1 IDE. \libraries..
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
You need to restart your IDE after you install one for it to see the new one.
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Quote
The currently recommended procedure for installing extra libraries is explained here --> http://arduino.cc/en/Guide/Libraries <-- .
If you do it the way Nick mentions, which will indeed work, you then must remember to reinstall the library whenever you upgrade to a newer Arduino release.
In either case you have to restart the IDE as Mike mentioned.
Don
Logged
alabama
Offline Offline
Full Member
View Profile
patra,
After at least Arduino1.0.1 the LiquidCrystal_I2C library is included.
If you do download one be sure to use this https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads. It is the same one used by the official release and is faster and more complete than any other. Thanks go to FM for his outstanding work. There are complete instructions included in the .zip. If you do put it in the Arduino sketchbook /librariesfolder (recomended) makes  sure you find the actual Arduino program folder, go to the libraries folder there and move the old LiquidCrystal library to a completely different location or delete it entirely.  Two libraries with the same name will cause conflicts.
TomJ
Logged
Einstein once said you don't really understand anything until you can explain it to your Grandmother
Pages: [1]   Go Up
Print
Jump to:
