Topic: Switch-case loop problem?! (Read 3827 times) previous topic - next topic
SparksInside
@Arrch
#include <Servo.h>
int var = 0;
int Lstate = 2;      // pin 2 - citire
int var_Lstate = 0;
int pos_tm1 = 120;     // 127 best
int pos_tm2 = 30;    // variable to store the servo position
Servo myservo_tm;
int flag_tm1 = 0;
int flag_tm2 = 0;
long prag_steptm1 = 0;
long prag_steptm2 = 0;
long prag_tm1 = 0;
long prag_tm2 = 0;
{Serial.begin(9600);
pinMode (Lstate, INPUT);  // sets pin 2 as digital input
myservo_tm.attach(5);
  myservo_tm.write(120);
  var_Lstate = digitalRead(Lstate);    // reads the status of the sensor
  //Serial.println(flag_tm2);
  //Serial.println(flag_tm1);
  //Serial.println(var_Lstate);
Serial.println(var);
   if(flag_tm1 == 1)
    if(millis() - prag_steptm1 > 55)
      prag_steptm1 = millis();
      if(pos_tm1 > 29)
        pos_tm1--;
        myservo_tm.write(pos_tm1);
      flag_tm1 = 0;
   if(flag_tm2 == 1)
    if(millis() - prag_steptm2 > 55)
      prag_steptm2 = millis();
      if(pos_tm2 < 121)
        pos_tm2++;
        myservo_tm.write(pos_tm2);
      flag_tm2 = 0;
  switch(var)
  case 0:
      pos_tm1 = 120;
      pos_tm2 = 30;
      if(var_Lstate == 0)
      prag_tm1 = millis();
      prag_tm2 = millis();
      var = 1;
  break;
  case 1:
      if( millis() - prag_tm1 > 3000)
      flag_tm1 = 1;
    if( millis() - prag_tm2 > 10000)
      flag_tm2 = 1;
      var = 0;
  break;
Still doesn't work properly...
PeterH
... but you aren't going to tell us what it's doing wrong?
PaulS
Read something. Print something else. I miss how the print() is useful.
Arrch
#18
Mar 23, 2013, 03:45 pm Last Edit: Mar 23, 2013, 03:51 pm by Arrch Reason: 1
[code]    if( millis() - prag_tm2 > 10000)
     flag_tm2 = 1;
     var = 0;
So after 10 seconds, go back to state 0 and
 case 0:
     pos_tm1 = 120;
     pos_tm2 = 30;
Reset your positions, regardless of whether or not the servos have run their course? Once you hit state 0, your increments and decrements become ineffective. You should only be resetting your values until after you are sure that they are done moving. Perhaps it would be better to do that the same time you clear their flags, or better yet, add a 3rd state that will wait until both flags are cleared before resetting the position values and returning to state 0. Paying closer attention to what happens during the states and during the transitions will also help down the road. That was why I posted the previous helper functions for changing states.
switch (state)
 case FIRST:
   // this happens every loop, when it is in this state
   if (some condition exists)
     // set the state variable to SECOND
     // this will only occur once, during the transition from FIRST to SECOND
   break;
 case SECOND:
You also should take some steps to remove redundant code. Obviously, you are going to be expanding on this, so having additional lines of code and variables is going to make it more difficult to debug. Hint: You don't need two prag_tmX variables and your check for flag and check for interval can be done on a single line.[/code]
SparksInside
It's working now, thank you very much Arrch
#include <Servo.h>
int var = 0;
int var_Lstate = 0;
Servo myservo_tm;
int flag_tm1 = 0;
int flag_tm2 = 0;
long prag_tm1 = 0;
long prag_tm2 = 0;
long prag_pos = 0;
//  Serial.println(flag_tm2);
//  Serial.println(flag_tm1);
//  Serial.println(var_Lstate);
//Serial.println(pos_tm2);
   if(flag_tm1 == 1)
      if(pos_tm1 > 29)
        pos_tm1--;
      flag_tm1 = 0;
   if(flag_tm2 == 1)
      if(pos_tm2 < 121)
        pos_tm2++;
      flag_tm2 = 0;
  switch(var)
  case 0:
      if(var_Lstate == 0)
     // pos_tm1 = 120;
     // pos_tm2 = 30;
      var = 1;
  break;
  case 1:
      flag_tm1 = 1;
      flag_tm2 = 1;
      prag_pos = millis();
      var = 2;
  break;
  case 2:
     if(millis() - prag_pos > 10)
       if(flag_tm1 == 0 && flag_tm2 == 0)
         pos_tm1 = 120;
         pos_tm2 = 30;
         var = 0;
  break;
I know I used different variables for all things i wanted to do, and i know i could use the same variable for more than one thing but, the comitee of examiners don't know so well all this programming stuff and i wanted to be easy for them to track all the commands using representative variable names.
I know i could use one case for every action i want but, in this way it seems more easier to track the program (for ex: case 2 does x,y and z actions).
My entire code for the bridge is almost ready.If some1 is interested i'll post it too.
Thank you all again for your help.
PaulS
I hope that they don't surprise you. They may know far more than you think they do.
wildbill
If you want to make your code easier for your examiners to read, consider sorting out the indentation and whitespace in your sketch.
GoForSmoke
The IDE has Auto-Format in the Tools tab....
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
michinyon
Tollgate or tollbar.   Tollbooth makes no sense.
GoForSmoke
Tollbooth is what the operator stands inside. I've seen them since 1961, back in the age when they took money and gave change. By 64-65 they had Exact Change Only lanes but even to the mid-80's I knew a girl who worked in a tollbooth.
Maybe what makes sense depends on where you're from and where you've been.
