Topic: Several questions about datalogging project (Read 5679 times) previous topic - next topic
lomanas123
I am trying to create a special datalogger for reading tiny amounts o voltage diff,
however i have 2-3 questions about the datalogging problem.
first: i want to create several logs in the form of
Code: [Select]
//Open the Data CSV File
  File dataFile = SD.open("test.txt", FILE_WRITE);
test1,
test2,
etc
i have tried
Code: [Select]
File dataFile = SD.open("test"+String(k)+".txt", FILE_WRITE);
but it's [font=Verdana]not [/font]working
second:
The dates on my output
all the text file on the Sd card are dated 1/1/2000
[img][file:///C:/Users/nerito/Pictures/arduino.jpg/img]
third :
any ideas how to uses floats on sd?
thank you in advance
Nick_Pyner
#1
Feb 27, 2013, 02:56 pm Last Edit: Feb 27, 2013, 03:46 pm by Nick_Pyner Reason: 1
Code: [Select]
test1,
test2,
etc
i have tried
Code: [Select]
Couldn't you just go
Code: [Select]
     myFile = SD.open(filename, FILE_WRITE);
 myFile.print(test1);
 myFile.print(",");
 myFile.print(test2);
 myFile.print(",");
etc
Quote
second:
Your Arduino has no idea what the date is and I guess the 1/1/2000 is just windows putting a name to nothing.
Your best bet is to get a real time clock and use that to name your files according to date and time. I record the time in the data and just use the date for the filename  - 20130218.csv
Quote
third :
Just declare your variable as a float and myfile.print them to SD.
lomanas123
Quote
I was so used of converting everything to String that i didn't thought it
So thanks!!
In the otherhand the other two answers didn't not help because:
Code: [Select]
  myFile.print(",");
  myFile.print(",");
i don't want to write something different i want to give different filename!
For the date i have to find a way to change it automatically...
Thanks in advance!
robtillaart
you can use sprintf to print to a char array.
something like  sprintf(filename, "test_%02d.csv", k);  google for exact syntax.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
lomanas123
That's a good idea, it worked and it is a clever one.
thanks.
Now anybody has an idea how to time the measuraments?
michinyon
I thought sprintf() doesn't work ?
If you want to know the time of your recordings,  you are going to need to get a real-time-clock module,
about $3 from ebay plus a little battery.
lomanas123
sprintf()
works correct
for char[];
about the time module have you got any suggections?
what to buy i mean
Nick_Pyner
have bought four of these.
http://www.ebay.com.au/itm/270985342203?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
How cn you go wrong at $2-36 incl postage?
Ahto
I'm learning Arduino RTC, too.
There seems to be 2 ways to go:
a) DS1307:  communication= I2C-bus, cheap, probably the right way to go, Nick's l
link is to one of these.
b) DS3234: communication = SP-bus, more accurate, more money...
There are Arduino libraries for both, maybe I2C is more easy?
lomanas123
Anyone knows and can suggest any external low noise ADC for arduino?
robtillaart
Today I got one of these - https://www.adafruit.com/index.php?main_page=adasearch&q=ads1115 -
not tested, not even read the datasheet, but it is capable of a few 100 samples @16 bit per second.
at 16 bits I expect low(er) noise
- http://adafruit.com/datasheets/ads1115.pdf -
at least it is an external one ;)
Rob Tillaart
lomanas123
thanks but since i am in europe i can't order from adafruit and the ADC you suggested is the smallest i have ever seen. I will never be cable of soldering it
RobertGetzner
for filedate/time google for something like this,I think it´s somewhere in the Fat16 Libs examples
Code: [Select]
* User provided date time callback function.
* See Fat16::dateTimeCallback() for usage.
void dateTime(uint16_t* date, uint16_t* time) {
  // User gets date and time from GPS or real-time
  // clock in real callback function
  // return date using FAT_DATE macro to format fields
  *date = FAT_DATE(year, month, day);
  // return time using FAT_TIME macro to format fields
  *time = FAT_TIME(hour, minute, second);
Just in case you have your arduino connected to a PC, you can set the date/time via serial. Of course not possible, if your arduino is not connectd.
Best, Robert
