Topic: Read from one character in string to another (Read 734 times) previous topic - next topic
AKSoapy29
Hello everyone,
I have a string of data in one of my Arduino programs, and I need to break it apart. The string will hold things like:
M1:1023;
M2:25;
or other things like that. I am wondering how I can great only things that are between : and ; so for M1, I would get 1023 saved to a variable. For M2, 25 would be saved to that variable.
I was watching a video on Youtube about I2C, and Jeremy did, what he used things like data_length(); and data.substring(); except that was in Processing.
Andrew K.
guix
#1
Mar 16, 2013, 01:27 am Last Edit: Mar 16, 2013, 01:33 am by guix Reason: 1
Hello :)
Using sscanf is the easiest solution I think.
int var;
char str[] = "M1:1023;";
sscanf( str, "M1:%d;", &var );
// var is now = 1023
Edit: sorry I meant, sscanf not sprintf ;)
majenko
Hello :)
Using sprintf is the easiest solution I think.
int var;
chat str[] = "M1:1023;";
sprintf( str, "M1:%d;", &var );
Not with sprintf you won't.  That will put "M1:308" into the variable str (where 308 is the address of the variable "var").
I think you meant sscanf().
guix
Of course... I'm a little tired :smiley-zipper:
There is another solution that is, using atoi, like this:
int var = atoi( &str[3] );
//var now = 1023
AKSoapy29
Awesome! Thank you. I don't know anything about atoi, but wouldn't that make var = 1023; instead of 1023?
Andrew K.
PaulS
int var = 27;
What is the value in var? 27 or 27;?
If you said 27;, you were wrong.
AKSoapy29
int var = 27;
Ok, I was just curious because I have never used atoi before.
Andrew K.
PaulS
Or googled it either, apparently.
