Topic: Issues with StackArray library when passing object to function (Read 778 times) previous topic - next topic
dmayman
Hi there,
I'm using the StackArray library to create a few StackArray objects that I'd like to pass by reference to a function. Here's my code:
#include <StackArray.h>
StackArray <int> BD_rgb_stack;
StackArray <int> SD_rgb_stack;
StackArray <int> ST_rgb_stack;
StackArray <int> FT_rgb_stack;
void setup(){
void loop(){
  build_simple(BD_rgb_stack);
void build_simple(StackArray<int> drumArray){
  //builds a simple stack
    drumArray.push(1);
    //end stack
And here's the error:
test.ino: In function 'void loop()':
test:33: error: 'build_simple' was not declared in this scope
It seems to be an issue with how the StackArray object is being passed to the build_simple() function. Am I declaring this function incorrectly?
Thanks!
UKHeliBob
What are you trying to push onto a stack and which stack is it going on ?
At first sight you seem to be trying to push the BD_rgb_stack stack onto a stack called drumArray that has not even been declared but bear in mind I know nothing about the StackArray library.
Incidentally, I would be interested to know what you are going to use the stacks for and why ?
pYro_65
#2
Mar 16, 2013, 11:23 am Last Edit: Mar 16, 2013, 11:25 am by pYro_65 Reason: 1
You need to specify a reference in the formal parameter list ( function arguments ),
void build_simple( StackArray<int> &drumArray );
Also place that line at the top of your sketch to declare the function ( or above its first use ). Here is a fixed sketch:
void build_simple(StackArray<int> &drumArray);
void setup(){
void loop(){
void build_simple(StackArray<int> &drumArray){
   drumArray.push(1);
   //end stack
Forum Mod anyone?
https://arduino.land/Moduino/
pYro_65
On inspection of the stack:
// push an item to the stack.
template<typename T>
void StackArray<T>::push (const T i) {
  // check if the stack is full.
  if (isFull ())
    // double size of array.
    resize (size * 2);
  // store the item to the array.
  contents[top++] = i;
It effectively chews double the memory it needs, that's less than 512 ints on an Uno which could easily support an array of close to 1000 ints.
Forum Mod anyone?
dmayman
Oh wow, I had no idea I had to declare a function before using it. You don't usually have to do that for functions - why for this one? For anyone else confused, I found more info on this here: http://www.cplusplus.com/doc/tutorial/functions2/ - scroll down to Declaring Functions.
Obviously these were just placeholders for the real code I'm building within these functions. I just couldn't get the build_simple function to even accept the StackArray object, so I simplified it for the sake of this post. I will start to put my real code in and see how it takes it. Thanks for the help!
PaulS
Because the IDE usually does that for you. It does not understand how to do that for reference variables or templates.
