Topic: rotate DC-Motor 180 degrees in both directions ? (Read 2428 times) previous topic - next topic
dany151
hi
kindly, i have a DC-Motor and arduino mega ...i wanna rotate DC-Motor 180 degrees in both directions...how to do that pls? ...
Grumpy_Mike
Is the motor geared? If not you can't control a normal DC motor to just rotate half a turn.
dany151
no it is just a DC-Motor ...but i have another motor, its a stepper motor with 6 pins ...i dont know how to use it...its name (motor-unipolar stepper:PM55L-048-HPG9 aka C2164-60045 NBM-MAT Stepper motor with metal gear) can i use it ..and how ?
dany151
thank you , i think that the 4 pins circuit in this page is helpfull
http://arduino.cc/en/Reference/StepperUnipolarCircuit
but my motor wires are all black and im dont sure of the right positions...maybe i will try
Grumpy_Mike
Quote
Measure the resistance between the wires. The wire that is connected to all the others with the lowest resistance is the common one.
They wire the other four any way. If the motor chatters instead of turning then swap two wires over and try again.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
