Topic: ABC - Arduino Basic Connections (Read 100491 times) previous topic - next topic
Docedison
I had the great fortune to see these wonderful drawings about a week or so back...
In over 50 years in this industry (Electronics) I have NEVER seen the equivalent. It's one half of a basic electronics course... On Flash Cards...
I did notice that some of the color codes would seriously bear re-visiting.
This work would do VERY WELL WITH IT'S OWN SECTION... IMNSHO IT IS THAT IMPORTANT... on another thought...
I Wonder how long before it shows up on Ebay as part of an "Arduino Training Kit"... Sold By SainSmart?
Bob
--> WA7EMS <--
JimboZA
Maybe you can write the other half Doc  8)... perhaps a beginner's explanation of the theory of each of the pix, to be printed back-to-back... And of course the "third half" would be a sketch to go with each.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
nickgammon
Every operating system I know of these days supports .zip files because they have been around so long. For example on my Mac it opens them just by double-clicking. And when I RH-click and select "compress X" it produces a .zip file.
As a comparison I took disp11e.pdf (one of the ABC cards) which is 142 kB. I zipped it (on the Mac) and got 85 kB. So, almost half.
More info:
nickgammon
On the Arduino software downloads page (http://arduino.cc/en/Main/Software) the Mac version is supplied as a .zip file.
Ubuntu and other Linux variants have zip decompression software either supplied already or available for free.
More info:
sonnyyu
1. PDF is to a large extent is compressed Postscript. So would not get any compression program to compress it further or only a little.
2. As extension of PDF, most modern browser is able open it for online read.
3. The zip extension is too wintel centric.
1- 85/142=1-60%=40%
40% is not a little, good catch.  normal pdf to a large extent is compressed Postscript, like ebook from publisher. compress it further do recieve that much gain. however pdf support much more object other than text. i.e. font, image... at OP case is pdf with embed image.
average zip compress ratio at jpeg is 20-25%. here is 40%. some fine tune might need. This the question for OP, What is app you use?
edit object images at this pdf,
acrobat->view->tool->edit object
pighixxx
Card 11 on line.
Download here
Next cards:
  • use i2c to connect a lcd
  • connect a Nokia 5200 / 3100 lcd
Thanks to all!
pighixxx
Card 12 on line.
Download here
Next cards:
  • connect a Nokia lcd
  • drive a stepper motor
Thanks to all!
pighixxx
Graynomad
Really nice work again pighixxx.
______
Rob
pighixxx
pighixxx
dkerfoot
These are great - Thank you for creating them!
One issue - I am putting them into MS Word so that I can print them out two per page.  (Insert - Object - PDF)
This worked fine up through "a".  After that, none of them display properly.  Did you change the way you are saving the new ones?
Thanks!
pighixxx
(cut)
Thanks!
Hi dkerfoot,
Yes, I changed the system because someone has taken away my logo (I do not understand are free!). When I finished the work I make a single pdf.
Thank you!
dkerfoot
Great - Thanks!
Do consider a 2-per page option.  That seems to me like the best reference size for these.  Whatever you do - these are a great help to the entire community.  Thank you!
pighixxx
Great - Thanks!
Thanks!
Due the high traffic my digital download system has crashed  :|
Site is now on line. I've put direct download to diagrams! (Atmega & Arduino)
Thanks,
Pighixxx
