Loading...
Pages: [1] 2   Go Down
Author Topic: iMall iTeadStudio PCB Ordering Process?  (Read 1265 times)
Offline Offline
Sr. Member
View Profile
I just placed my first order with iTeadStudio... going to try them out.
I'm a little confused by their system... I've already paid for my order via Paypal, but when/where do I upload my Gerber ZIP files?
Do I sent it via email, or is it under My Account?
Can anyone with experience ordering from iTead let me know what I'm missing. Thanks.
Logged
Grand Blanc, MI, USA
Offline Offline
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
Just sent one this afternoon myself. Send it to: pcb@iteadstudio.com. I always just send a zip file with the Gerbers in it. I use my order number for the filenames (Gerbers and zip), but this is not a requirement of theirs. I also tend to put the order number on the board, just for my reference, but I figure it can't hurt.
Their requirements as well as the email address are at the bottom of the page for whatever particular board you're ordering, e.g. http://imall.iteadstudio.com/open-pcb/pcb-prototyping/im120418001.html
« Last Edit: March 16, 2013, 06:41:03 pm by Jack Christensen » Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Offline Offline
Sr. Member
View Profile
Ahhh thanks. I didn't read all the instructions.
Their ordering system is a little primitive and a hack job. We'll see how their service goes.
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
where do you put the outline? it says one of the layers, what should that layer be called?
most people want it in the drill file
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Use their .cam file
File:Cam processor, new window opens
File:Open:Job, browse to the iteadstudio .cam file you previously saved
Select Process Job.
Zip the 13 files newly created (not .sch & not .brd), and send to pcb@iteadstudio, include the Order number you got back after paypal payment was sent.
Make sure any errors are resolved on schematic (Tools:ERC)
and on the board (Tools:DRC, Load - select Itead_rule.dru you previously saved, Check).
« Last Edit: March 16, 2013, 10:30:46 pm by CrossRoads » Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
I dont use eagle and it barfs in altium
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Sorry about that.
Logged
Offline Offline
Faraday Member
View Profile
WWW
Things are fairly basic, but service has been good for me.
The page I linked above lists the following, but their CAM job also produces a milling file (.GML) which has the outline, so I send that too, eight files in all.
Quote
2.Gerber files needed for 2-layer PCB boards:
    Top layer:    pcbname.GTL
    Bottom layer:    pcbname.GBL
    Solder Stop Mask top:  pcbname.GTS
    Solder Stop Mask Bottom pcbname.GBS
    Silk Top:   pcbname.GTO
    Silk Bottom pcbname.GBO
    NC Drill: pcbname.TXT
« Last Edit: March 17, 2013, 06:32:38 am by Jack Christensen » Logged
Offline Offline
Sr. Member
View Profile
If there is`nt one, someone should make a youtube tutorial about how to submit an order from them. smiley
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
For all the people too lazy to read the
"How to make your design fabricated"
section of the ordering page?
I refuse on principal.
Logged
Offline Offline
Sr. Member
View Profile
I hope itead works out.... beyond a certain size, OshPark's prices becomes expensive. OshPark is great though for tiny and small boards.
So I'm trying to use iTead for this medium sized prototype board.
Usually, I use an American company but at $100 for 5 boards (for any size... 1x1 up to 8x8 and bigger). However $100 for 5pcs of small and medium sized prototype boards is not a good bargain. For large prototype boards though, they're great.
On mass-production runs (100pcs, 250pcs and above), I use yet a different Chinese company (since '07). They charge tooling on the first run, but not on subsequent re-orders.
I'm spoiled by the other PCB companies with their instant online calculator, and web-based file uploads to update layers or  maintain your gerbers.  iTead's ordering workflow is not so good... and more suited for an online retail environment.
Logged
Offline Offline
Sr. Member
View Profile
Fair enough.
I was thinking about first timers, for their first pcb design, could maybe be intimidated by the ordering process and need a bit of hand holding through the process.
Still at $10 plus shipping, if a mistake is made, its not the end of world. smiley
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
If you are using Altium you can just send the PcbDoc file, they don't need Gerbers.
Quote
I've used both iTead and LCBCart.
The proto services like iTead sound cheap and they are under the right circumstances, but I need 10 different boards done so I costed a panel with 10 designs as opposed to 10 boards done with iTead.
Result, MUCH cheaper to panalize the boards and use a professional fab house. $880 for 10 designs (10 boards each) from iTead, $673 for 10 panels each with 10 designs from PCBCart.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
Quote
well I sent them a pile of gerbers, if they have any problems I can send them the pcb file, heck they can have the whole project folder as far as I am concerned, theres nothing magical about the hardware
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
I use seeedstudio and used iteadstudio some years ago. It sounds like itead has not updated their ordering system a bit. Now with seeed you can upload files. I have a tutorial for them. Same price as itead and free shipping for orders over $50
http://liudr.wordpress.com/2012/12/22/ordering-pcb-from-seeedstudio/
Logged
Pages: [1] 2   Go Up
Print
Jump to:
