« on: March 16, 2013, 05:47:37 pm » |
I just placed my first order with iTeadStudio... going to try them out.
I'm a little confused by their system... I've already paid for my order via Paypal, but when/where do I upload my Gerber ZIP files?
Do I sent it via email, or is it under My Account?
Can anyone with experience ordering from iTead let me know what I'm missing. Thanks.
Grand Blanc, MI, USA
Online
"We're a proud service of the Lost Electricity Reclamation Agency"
« Reply #1 on: March 16, 2013, 06:39:05 pm » |
Just sent one this afternoon myself. Send it to: pcb@iteadstudio.com. I always just send a zip file with the Gerbers in it. I use my order number for the filenames (Gerbers and zip), but this is not a requirement of theirs. I also tend to put the order number on the board, just for my reference, but I figure it can't hurt. Their requirements as well as the email address are at the bottom of the page for whatever particular board you're ordering, e.g. http://imall.iteadstudio.com/open-pcb/pcb-prototyping/im120418001.html
« Last Edit: March 16, 2013, 06:41:03 pm by Jack Christensen »
« Reply #2 on: March 16, 2013, 09:56:04 pm » |
Ahhh thanks. I didn't read all the instructions.
Their ordering system is a little primitive and a hack job. We'll see how their service goes.
SE USA
@ssh0le
« Reply #3 on: March 16, 2013, 10:14:41 pm » |
where do you put the outline? it says one of the layers, what should that layer be called?
most people want it in the drill file
Boston area, metrowest
Online
« Reply #4 on: March 16, 2013, 10:26:11 pm » |
Use their .cam file File:Cam processor, new window opens File:Open:Job, browse to the iteadstudio .cam file you previously saved Select Process Job. Zip the 13 files newly created (not .sch & not .brd), and send to pcb@iteadstudio, include the Order number you got back after paypal payment was sent.
Make sure any errors are resolved on schematic (Tools:ERC) and on the board (Tools:DRC, Load - select Itead_rule.dru you previously saved, Check).
« Last Edit: March 16, 2013, 10:30:46 pm by CrossRoads »
SE USA
@ssh0le
« Reply #5 on: March 16, 2013, 10:33:29 pm » |
I dont use eagle and it barfs in altium
Online
« Reply #6 on: March 16, 2013, 11:56:22 pm » |
Sorry about that.
Online
« Reply #7 on: March 17, 2013, 06:30:08 am » |
Things are fairly basic, but service has been good for me. where do you put the outline? it says one of the layers, what should that layer be called?
The page I linked above lists the following, but their CAM job also produces a milling file (.GML) which has the outline, so I send that too, eight files in all. 2.Gerber files needed for 2-layer PCB boards:
Top layer: pcbname.GTL Bottom layer: pcbname.GBL Solder Stop Mask top: pcbname.GTS Solder Stop Mask Bottom pcbname.GBS Silk Top: pcbname.GTO Silk Bottom pcbname.GBO NC Drill: pcbname.TXT
« Last Edit: March 17, 2013, 06:32:38 am by Jack Christensen »
« Reply #8 on: March 17, 2013, 06:49:18 am » |
If there is`nt one, someone should make a youtube tutorial about how to submit an order from them.
Online
« Reply #9 on: March 17, 2013, 02:20:19 pm » |
For all the people too lazy to read the "How to make your design fabricated" section of the ordering page? http://imall.iteadstudio.com/open-pcb/pcb-prototyping/im120418001.htmlI refuse on principal.
« Reply #10 on: March 17, 2013, 02:52:12 pm » |
I hope itead works out.... beyond a certain size, OshPark's prices becomes expensive. OshPark is great though for tiny and small boards.
So I'm trying to use iTead for this medium sized prototype board.
Usually, I use an American company but at $100 for 5 boards (for any size... 1x1 up to 8x8 and bigger). However $100 for 5pcs of small and medium sized prototype boards is not a good bargain. For large prototype boards though, they're great.
On mass-production runs (100pcs, 250pcs and above), I use yet a different Chinese company (since '07). They charge tooling on the first run, but not on subsequent re-orders.
I'm spoiled by the other PCB companies with their instant online calculator, and web-based file uploads to update layers or maintain your gerbers. iTead's ordering workflow is not so good... and more suited for an online retail environment.
« Reply #11 on: March 17, 2013, 03:43:49 pm » |
Fair enough. I was thinking about first timers, for their first pcb design, could maybe be intimidated by the ordering process and need a bit of hand holding through the process. Still at $10 plus shipping, if a mistake is made, its not the end of world.
nr Bundaberg, Australia
Online
« Reply #12 on: March 17, 2013, 08:09:40 pm » |
I dont use eagle and it barfs in altium If you are using Altium you can just send the PcbDoc file, they don't need Gerbers. I hope itead works out.... beyond a certain size, OshPark's prices becomes expensive. OshPark is great though for tiny and small boards. I've used both iTead and LCBCart. The proto services like iTead sound cheap and they are under the right circumstances, but I need 10 different boards done so I costed a panel with 10 designs as opposed to 10 boards done with iTead. Result, MUCH cheaper to panalize the boards and use a professional fab house. $880 for 10 designs (10 boards each) from iTead, $673 for 10 panels each with 10 designs from PCBCart. ______ Rob
SE USA
@ssh0le
« Reply #13 on: March 17, 2013, 10:22:55 pm » |
I dont use eagle and it barfs in altium If you are using Altium you can just send the PcbDoc file, they don't need Gerbers. well I sent them a pile of gerbers, if they have any problems I can send them the pcb file, heck they can have the whole project folder as far as I am concerned, theres nothing magical about the hardware
Central MN, USA
« Reply #14 on: March 28, 2013, 06:10:45 pm » |
I use seeedstudio and used iteadstudio some years ago. It sounds like itead has not updated their ordering system a bit. Now with seeed you can upload files. I have a tutorial for them. Same price as itead and free shipping for orders over $50 http://liudr.wordpress.com/2012/12/22/ordering-pcb-from-seeedstudio/
