Pages: 1 [2] 3 4   Go Down
Author Topic: analog in to 4 bit LCD driver  (Read 4479 times)
London
Hi Alvaro,
If I understand your first question correctly, you want to print your number in decimal on the LCD.
See the section "Printing Numbers" on the LCD wiki page:
http://www.arduino.cc/playground/Code/LCD
Remember that the LCD library print() functions accept single ascii characters or strings of characters.  So first you have to convert your number into a string representation.  The wiki section above shows how to do this using the itoa() function.
It might make sense for the LCD library to provide another function, say printNumber(int) which took an integer and printed its string representation in decimal.
neillzero
First off, kudo's for the instructions in the 4bit playground page. If I had been paying attention to the datasheet I found for my display, I'd have got it working the first time smiley (For some reason the pin numbering is ass-backwards on my LCD). Still, I have a small question. For now, the random fruit example works perfectly. Single line, scrolling, all the bits. But, if I enable the 2nd line and the commented out 'score' bit the display stays empty. No noise, no nothing. Backlight comes on, but no character appear. Am I missing something, or have my earlier attempts killed just the second line? The display is a pc1602f, which should be hd44780 compatible.
(excuse me for lifting this old thread from the depths of oblivion)
Thanks!
Andre
thanx a lot!
« Last Edit: April 04, 2008, 09:40:46 am by grandemahatma » Logged
http://arduinors.net
Hello Neillzero.
Congratulation by LCD4bit lib. I'm using and it's very very custom.
But, I have a suggestion:
Currently, I formatted my computer, but the pins had changed the lib in itself. cpp.
So when I installed again my system and upload to arduino, my display doesn't worked.
So again I edit in your CPP the pins.
You should create methods to set the number of pins.
Thanks
Denmark
 Hey Neilzero..
Ive adapted your code into my little program, but can't find out how to make it show the temperature as 26,1 as oposed to the 261 format it is in now ?!?! Im sure you have a solution, I just can't see it since i've only been into arduino programming for about 4 days now  :-/
My code is at the bottom.
 int heat = 451;
  char heat_str[4] = "   ";  //reserve the string space first
  itoa(heat, heat_str, 10);
  lcd.printIn(heat_str);
  //todo: make sure number can be notated within str length.
My code..
#include <LCD4Bit.h>
LCD4Bit lcd = LCD4Bit(2);
int temperaturePin = 2;    // select the input pin for the temperature
  lcd.init();
  lcd.clear();
  lcd.printIn("Vandtemperatur :");
  int i, val = 0;
  for(i = 0; i < 20; ++i)
       val += analogRead(temperaturePin);    // read the value from the sensor
       delay(50);
  val /= 4.06;      // conversion value to millivolts
   if(val > 28 * 10)   // temperature in deg C times 10, since we're measuring to tenths of a degree
     digitalWrite(13,HIGH);
     digitalWrite(13,LOW);
     int heat = val;
  char heat_str[5] = "    ";  //reserve the string space first
  itoa(val, heat_str, 10);
  lcd.cursorTo(2, 5);  //line=2, x=6.
 Thanks... Martin
« Last Edit: August 24, 2008, 05:49:47 am by Solow » Logged
neillzero,
Thanks so much for the trouble shooting help! I've been sitting here looking over the wiring over and over and over, wondering what could be wrong.
Turns out, once I delete LCD4bit.o and recompiled the code, it worked perfectly! I'm glad I found your post, maybe this should be in the wiki? Maybe it is and I missed it!
Thanks again!
veroboaring is the new XGame - Extreme Veroboarder
My 2 playing with 4 bits LCD...
I always use LCD4Bits library...but i build it with a new LCD WH1602, and do not work...
in the Lib note this:
// ########## pin assignment ##########
int RS = 12;      // Register Select
int RW = 11;      // Read/Write
int En = 2;            // Enable
//DB should be an unseparated group of pins - because of lazy coding in push_nibble()
int DB[] = {7, 8, 9, 10};  // DB4 .. DB7
That on the default lib, my Lib:
int RS = 3;      // Register Select
int DB[] = {8, 5, 7, 6};  // DB4 .. DB7 :o
So this is not working... could be the pin assignment?
Best Regards!
Frank
Sweden, Malmö
Rooky
Hey Neilzero..
Solow, read the attached post and you will get it.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1218132924/8#8
Hey,
im using this lcd http://www.sparkfun.com/commerce/product_info.php?products_id=709
and i cant get it to work, i followed your post http://www.arduino.cc/playground/Code/LCD4BitLibrary
is it my lcd isnt compatible or am i doing something wrong?
Thanks
I've got a question, I haven't seen anyone else getting these strange results.
I have a HD44780 LCD and finally got it to display characters with the example.  Only problem is, I don't see fruits I see characters like ->, 0, etc.  It's like the character map used isn't correct for my LCD.  Can these vary by LCD or isn't the ascii universal?
Any ideas?  I've been playing with pins and am going to start probing to make sure all my connections are being made.  Anything else I should look for?
EDIT
Nevermind my dumb question.  I was feeding corrupt data (data pins were backwards)
« Last Edit: December 09, 2008, 08:48:04 am by syko82 » Logged
This is a great thread.  Thanks for contributing.  Just thought I'd capture the landmark I stumbled upon
Hi, i came across these lines in your great library:
void LCD4Bit::printIn(char msg[]) {
  uint8_t i;  //fancy int.  avoids compiler warning when comparing i with strlen()'s uint8_t
  for (i=0;i < strlen(msg);i++){
    print(msg[i]);
In my opinion you don't need to include <string.h> and you don't need that fancy int8_t. Take a look:
      int i = 0;
      while(msg[i])
            print(msg[i]);
            i++;
greetings sunny
London
Have fun!
That is an improvement. But why not use the LCD code provided in release 0012. It has much richer print functionality with the added benefit that it uses the same syntax as the  Serial print routines.
That's a good question. I haven't looked at that one yet. But i will do. Thx mem!
Hello,
I think I have an improvment to this great library.
I did some writing to the second line of my display and that will take 117msec to position and write the line content.
After looking around, i found this site: http://www.geocities.com/dinceraydin/lcd/commands.htm and there is the command 0x080 to position the cursor directly, with going to home position and move left the cusor position.
I now wrote a simple method to test this (no error handling, just a proof of concept :-) ):
void myCursorTo(int aLine, int aCol)
    int CmdToWrite = 128; //0x80
    switch(aLine)
        case 1:
            CmdToWrite = CmdToWrite + aCol;
            break;
        case 2:
            // this line is buggy, jumps only to first column of line 2
            CmdToWrite = CmdToWrite + 40 + aCol;
            break;
    lcd.commandWrite(CmdToWrite);
By using this to position the cursor, moving to second line and writing the content now just needs 35msec. A really great speed improvement.
Cheers
KiWiX
« Last Edit: February 02, 2009, 01:51:48 pm by kiwix » Logged
Pages: 1 [2] 3 4   Go Up
