Loading...
Pages: [1]   Go Down
Author Topic: Boards.txt overflow  (Read 226 times)
North Carolina
Offline Offline
Newbie
View Profile
It has finally happened. I have too many Arduino compatible boards. Why doesn't the IDE take the number of boards into account? When I go to the menu to select the board I'm going to program the newest ones that I've added are below the bottom edge of the screen.
To select the board I'm programming, I have to:
  • Open the "boards.txt" file.
  • Find the board I am programming.
  • Manually count it's place in line.
  • THEN I have to go back to the IDE
  • Press the down arrow until I'm pretty sure it is on the right board.
  • Press <ENTER> and hope the board that shows in the bottom right corner is the correct one.
WHAT A PAIN! I hope the next version has a scroll bar if all the boards don't fit on the screen at once.
Is there a workaround besides creating two separate files and figuring out which one needs to be loaded on starup?
Logged
If it was easy, everyone would do it.
Offline Offline
Edison Member
View Profile
Buy a larger screen ?
Did you try verion 1.5.2 ?  It has a seperate menu for the microcontroller type. So the boards menu use less space.
Logged
Pages: [1]   Go Up
Print
Jump to:
