Topic: Broken Menu example (Read 1 time) previous topic - next topic
0miker0
I was wondering why the Menu example is broken for 1.0.3 at http://playground.arduino.cc/Code/Menu? I have installed the library accoring to the instructions and restarted the program. When I verify the code I get the following errors:
In file included from SerialMenu.pde:1:
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/Menu.h:33:22: error: WProgram.h: No such file or directory
In file included from /Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/Menu.h:34,
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/interfaces/MenuInterface.h:41: error: 'byte' has not been declared
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/interfaces/MenuInterface.h:47: error: 'byte' has not been declared
In file included from /Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/SubMenu.h:35,
                 from /Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/MenuItem.h:35,
                 from /Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/Menu.h:36,
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/interfaces/SubMenuInterface.h:43: error: 'byte' has not been declared
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/interfaces/SubMenuInterface.h:48: error: 'byte' has not been declared
In file included from /Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/MenuItem.h:35,
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/SubMenu.h:46: error: 'byte' has not been declared
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/SubMenu.h:51: error: 'byte' has not been declared
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/SubMenu.h:53: error: 'byte' does not name a type
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/SubMenu.h:54: error: 'byte' does not name a type
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/SubMenu.h:55: error: 'byte' does not name a type
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/Menu.h:51: error: 'byte' has not been declared
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/Menu.h:59: error: 'byte' has not been declared
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/Menu.h:62: error: 'byte' does not name a type
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/Menu.h:63: error: 'byte' does not name a type
/Applications/Arduino.app/Contents/Resources/Java/libraries/Menu/Menu.h:64: error: 'byte' does not name a type
MarkT
If WProgram.h is mentioned as in that set of errors it means the library has not been updated for Arduino 1.0 and later.
References to WProgram.h should be replaced by Arduino.h, or conditionally like this:
Code: [Select]
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
#else
  #include "WProgram.h"
#endif
As the contact details are on that page I'd suggest contacting the author and suggesting
it be updated.
