Topic: ML-1400 PLC and arduino (Read 6551 times) previous topic - next topic
dhruvit
hello friends
i am trying to connect my plc ml-1400 with arduino serially
i want to know that do i need rs232 ttl convertor while serially connecting both device
or directly  connecting  arduino rx pin to my plc tx pin and vice versa will work??
psyoptica
How do u start a new post on arduino forum?
Ufoguy
Can you tell us what a "plc ml-1400" is?
If you want to meet a beautiful nurse you must be patient.
WB7ODYFred
If you have one of these Micro Logix 1400 PLC, why would you need an arduino?
http://ab.rockwellautomation.com/programmable-controllers/micrologix-1400#/tab5
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1766-um001_-en-p.pdf  User Manual
http://literature.rockwellautomation.com/idc/groups/literature/documents/rm/1766-rm001_-en-p.pdf  Reference Manual
RS-232  is -10V to +10V  (ie +-15V swing)
Arduino  is +5V device signalling 0V-5V RS-232.  So you need a level shifter IC to switch the 0V-5V to a +10V -10V RS-232 Standard level.
The device to look at is  a Maxim Integrated circuits MAX23
http://en.wikipedia.org/wiki/MAX232  Wikiepedia description
http://www.ti.com/lit/ds/symlink/max232.pdf  TI MAX232 Data sheet  16 pin chip
  MAX 232 Application Circuit Image
Google MAX232 and see what you can find for circuits and images.
Glad to help answer your question from Oregon USA, Fred
