Loading...
Pages: [1]   Go Down
Author Topic: DUE DAC output  (Read 700 times)
Offline Offline
Newbie
View Profile
Hello Everyone,
I am new to Arduino and hence, new to everything.
So can anyone please tell How to use 2 of the DAC pins present in Arduino Due, can they provide constant voltage output, if yes, then How ????
Sorry if this Question is a silly one but please, do guide.
Thank you
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Well using
Code:
analogWrite(DAC0, value );
will do it.
Guess how you access DAC1.
This will give you 8 bits resolution. To get the full 12 bits use:-
Code:
  analogWriteResolution(12);
in the setup.
Logged
Offline Offline
Newbie
View Profile
Thanks, It worked.
But can one tell me what is the min and max voltage output by these pins, because i tried this code:
Code:
int value=0;
analogWrite(DAC1, value );
value++;
delay(10);
if(value>4094)
value=0;
And the output didn't exceed 2.8 V (Due's Pins Support I/O up to 3.3V).
Thank you
Logged
USA
Offline Offline
Newbie
View Profile
WWW
<snip>
This is expected.
See stimmer's response on February 26 here:
http://arduino.cc/forum/index.php/topic,139733.msg1134372.html#msg1134372
(Page 1033 of a similar datasheet)
-Chris
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
yes that is the value I get from that code as well.
In fact you will see it does not go lower than 0.58V so the actual range is only 2.24V
Logged
Offline Offline
Newbie
View Profile
Got it.
Thanks for your Help  smiley-mr-green
Logged
Pages: [1]   Go Up
Print
Jump to:
