Offline
Newbie
« on: March 18, 2013, 05:55:41 pm » |
I'm new to Arduino and basically a stranger to most programing. I am an industrial designer working on an ocupational theorpy project for a client with Multiple Sclerosis. The problem I am tackling is that he falls asleep a lot in casual settings and wants an alarm type device that will keep him awake. I want the device to be hand held and fairly discrete (so as small a board as possible will be best). The program will be fairly simple. When turned on I want the device to begin to vibrate at random intervals and only turned off when he presses a button.
I am planning on reading up on the programing side of things and teaching myself as much as possible but I need some advice about which board to buy. What is the smallest stand alone board I can buy? If there are smaller boards that require some other piece can I somehow modify them to be semi stand alone?
I may check back in later for programing advice.
Thanks,
-Coby
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
I only know some basic electricity....
« Reply #1 on: March 18, 2013, 06:30:28 pm » |
Would a sound in the ear do? Using an ear bud that would take less power so less battery, smaller, lighter, etc.
Otherwise cheap, small, low power, noticeable vibrator would be a small DC motor that turns an off-center weight. The final package if using a surface mount ATtiny could be very small and be worn like a semi-thick (depending on motor) wrist watch.
You could try a piezo-based vibrator but I dunno if that little bit would wake me up.
Logged
Examples can be found at Learning in the Main Site and at the Playground
Offline
Newbie
« Reply #2 on: March 18, 2013, 06:59:37 pm » |
Sound in the ear was an idea originally but we decided that since this problem effects him mostly while talking to other people an audible alert would be too distracting. How much power can I run thorugh the ATiny? My non-programable mockup used 1.5 volts and was that seemed like enough. Also can I program the ATiny with Arduino software? How does that unit get connected to sensors and motors and such?
Thanks,
-Coby
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
« Reply #4 on: March 18, 2013, 08:28:07 pm » |
Maybe there's a change in pulse or skin resistance when the patient nods off? Then it won't have to be a persistent occasional stimulus. I suggest the tiny's because the are small (surface mount, less than 6mm square), have few pins and at low but more than you need speed ... • Low Power Consumption – Active Mode: • 1 MHz, 1.8V: 300 μA – Power-down Mode: • 0.1 μA at 1.8V It's the wake up kick that may eat your battery. But you may find a way around that. A simple DC motor just needs power. That's 1 pin ON or OFF and ground. Button... could be 1 pin or 2 for some forms of touch-sensor (capacitive sense, piezo disk, etc) that IMO have way longer lives than moving-part types. Yeah, if you have the core files for the chip, Arduino IDE can program just about any AVR. MIT High-Low Tech: http://hlt.media.mit.edu/?p=1695
Logged
Norfolk UK
Offline
Edison Member
« Reply #5 on: March 19, 2013, 02:29:53 am » |
The program will be fairly simple. When turned on I want the device to begin to vibrate at random intervals and only turned off when he presses a button. Instead of random time could you use accelerator sensor that triggers when the arm/wrist movement stops for X amount of time.
Logged
Offline
Full Member
« Reply #6 on: March 19, 2013, 04:12:16 am » |
You can buy very small vibrating motor, used in cell phones, search for "vibration motor" on ebay.
Not sure how to detect someone dozing off, but I think your idea of random alarm that requires him to turn it off might just be good enough.
Develope it on Arduino and then turn it into 8-pin app is definitely huge, as many have already suggested.
Logged
Search for "mjkzz" on eBay :-)
Offline
Newbie
« Reply #7 on: March 20, 2013, 03:06:52 pm » |
Thanks for all the help so far guys. I'm really new to this, so I apologize if my questions are so amateur.
If I understand correctly from what I've read so far I will need the ATtiny, an Arduino, and A breadboard, A ATtiny programer board, and a commercial programmer board and all the components I intend to use on the device it's self. Is this correct? Do I really need all of this?
Thanks agian,
-Coby
Logged
Offline
God Member
« Reply #8 on: March 20, 2013, 03:09:03 pm » |
You can use an Arduino as an ISP to program the ATtiny. Do you already have an arduino board?
Logged
Offline
Newbie
« Reply #9 on: March 20, 2013, 03:10:19 pm » |
No but I was just about to head out to RadioShack to buy one. What else will I need?
Logged
Offline
God Member
« Reply #10 on: March 20, 2013, 03:29:42 pm » |
Well, start with just an Arduino Uno for devlopment. You can take your code and put it in the Attiny later. You will need some NPN transistors with a CE current high enough for your motors, some resistors (they should sell an assortment pack) a vibrator motor, and a small breadboard.
That will get you started. Once you have it all developed, then look for an appropriate perfboard and enclosure and whatever accessories you need. Radioshack used to sell a little keyfob enclosure that would probably be enough to house everything.
Logged
Offline
Newbie
« Reply #12 on: March 24, 2013, 08:50:41 pm » |
So I've got my code and circuit basically figured out. I think I'm ready to load this onto a smaller unit. What exactly should I buy? There seem to be countless ATtinys out there. I only need to hook up a battery, button and motor plus the related resistors and such.
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
« Reply #13 on: March 24, 2013, 09:40:16 pm » |
You should start by determining how many I/O pins you need, how much flash and RAM.
Logged
Offline
Newbie
« Reply #14 on: March 24, 2013, 09:44:15 pm » |
Very minimal flash and ram. The code is embarrassingly simple. In terms of pins I will need one in and one out plus ground and power I suppose. Speaking of witch, how do I run power into the ATtiny?
Sorry for all of the beginner questions. A book is on order so I'll be asking fewer questions soon.
Logged
