I apologize for derailing this a little, but why is that code put into a do{} while(0) loop. That looks really odd to me and I'm sure there's a real good reason why it's done there. Isn't that the same as just executing the line of code once? Or is that just to add one more instruction (the comparison) so it doesn't return before it falls asleep?
It's a "standard" convention to do that in macros so that it behaves as much like a function as possible. Without the do{}while(0), you could get errors like:
#define bar(x) y = x; y++;
if (foo) bar(3);
which would unconditionally execute
y++, and if you do
#define bar(x) {y = x; y++;}
if (foo) bar(3);
then this would be legal:
if (foo) bar(3)
... etc. All to get around the overhead of a function call that would be optimized out anyway.
Anyway, I'm no expert in sleeping and I can't spend the time to look up the registers. However, remember that the chip will wake up whenever there's an interrupt, and if you keep timer0 enabled, there's an interrupt every 1ms to update the millia() timer. You also have to think about what you want to take up the chip, and if that's getting triggered prematurely.
