Topic: obstacle avoiding robot, help with code (Read 56934 times) previous topic - next topic
Shehjar
#include <Ultrasonic.h>
#include <Servo.h>
Ultrasonic ultrasonic(12,13);
const int RForward = 0;
const int RBackward = 180;
const int LForward = 180;
const int LBackward = 0;
const int RNeutral = 91;
const int LNeutral = 92; //constants for motor speed
const int TrigPin = 12;
const int EchoPin = 13;  //Echo pin
const int dangerThresh = 10; //threshold for obstacles (in cm)
int leftDistance = 0;
int rightDistance = 0; //distances on either side
Servo HeadServo;
Servo LeftServo;
Servo RightServo; //declare servos
long duration; //time it takes to recieve ECHO))) signal
pinMode(TrigPin, OUTPUT);
pinMode(EchoPin, INPUT);
RightServo.attach(11);
LeftServo.attach(10);
HeadServo.attach(6); //attach servo to proper pins
HeadServo.write(90); //centre head servo
int distanceFwd = (ultrasonic.Ranging(CM));
Serial.begin( 9600 );
Serial.print( ultrasonic.Ranging(CM) );
Serial.println( "cm" );
if (distanceFwd>dangerThresh) //if path is clear
LeftServo.write(LForward);
RightServo.write(RForward); //move forward
else //if path is blocked
LeftServo.write(LNeutral);
RightServo.write(RNeutral);
HeadServo.write(0);
rightDistance = ultrasonic.Ranging(CM); //scan to the right
HeadServo.write(180);
delay(700);
leftDistance = ultrasonic.Ranging(CM); //scan to the left
HeadServo.write(90); //return to center
delay(100);
compareDistance();
void compareDistance()
if (leftDistance>rightDistance) //if left is less obstructed
LeftServo.write(LBackward);
RightServo.write(RForward); //turn left
delay(2000);
else if (rightDistance>leftDistance) //if right is less obstructed
RightServo.write(RBackward); //turn right
delay(2000);
else //if they are equally obstructed
RightServo.write(RBackward); //turn 180 degrees
delay(2000);
long ping()
// Send out PING))) signal pulse
digitalWrite(TrigPin, LOW);
delayMicroseconds(2);
digitalWrite(TrigPin, HIGH);
delayMicroseconds(5);
//Get duration it takes to receive echo
pinMode(TrigPin, INPUT);
duration = pulseIn(TrigPin, HIGH);
//Convert duration into distance
return duration / 29 / 2;
AWOL
Is there a question?
Will we be seeing your code inside code tags?
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
PaulS
What is the ping() function for? You never call it.
compareDistance() is a dumb name for a function that does a whole lot more than that.
Sarazarvisphineix
Am making a obstical avoiding car...my whole circuit is ok.. but I am not been able to upload the codes....each time l try it doesn't compile and without compiling l can't upload the codes .. it shows that l have some data (newping)missing ...plz anybody help me with providing a valid code..
The code l used
  // Arduino Obstacle Avoiding Robot
 // Code adapted from http://www.educ8s.tv
 // First Include the NewPing and Servo Libraries
#include <NewPing.h>http:max
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
#define MAX_DISTANCE 200
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
Servo myservo;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
const int motorPin1  = 11;
const int motorPin2  = 10;
//Motor B
const int motorPin3  = 6;
const int motorPin4  = 5;
  myservo.attach(9);
  myservo.write(115);
  delay(2000);
  distance = readPing();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
 int distanceR = 0;
 int distanceL =  0;
 delay(40);
 if(distance<=20)
  moveStop();
  delay(100);
  moveBackward();
  delay(300);
  moveStop();
  delay(200);
  distanceR = lookRight();
  delay(200);
  distanceL = lookLeft();
  delay(200);
  if(distanceR>=distanceL)
    turnRight();
    moveStop();
  }else
    turnLeft();
    moveStop();
 }else
  moveForward();
int lookRight()
    myservo.write(50);
    int distance = readPing();
    delay(100);
    myservo.write(115);
    return distance;
int lookLeft()
    myservo.write(170);
    delay(100);
    myservo.write(115);
    return distance;
    delay(100);
int readPing() {
  delay(70);
  int cm = sonar.ping_cm();
  if(cm==0)
    cm = 250;
  return cm;
void moveStop() {
  analogWrite(motorPin1, 0);
    analogWrite(motorPin2, 0);
    analogWrite(motorPin3, 0);
    analogWrite(motorPin4, 0);
void moveForward() {
    analogWrite(motorPin1, 180);
    analogWrite(motorPin3, 180);
void moveBackward() {
    analogWrite(motorPin2, 180);
    analogWrite(motorPin4, 180);
void turnRight() {
  delay(300);
 moveForward();
void turnLeft() {
  delay(300);
   moveForward();
Sarazarvisphineix
Am using Arduino nano ATmega328 ... regarding that plz provide me a code
The components am using
1------WD4 robot chassis
2-------arduino nano AT MEGA 328
3--------ultrrasonic senior
4--------Robodo Electronics L298 Motor Driver Module
5-----BB-801 400 Tie Point Solderless Breadboard Circuit Experiment Accessory
6-----BRC 18650 6800mah battery
PaulS
Code: [Select]
What is THAT nonsense?
Quote
For a (n astronomical) fee. Writing the code is YOUR job.
slipstick
You have a code. If you post the actual error messages you get trying to compile it we can help you get it going.
Then all you need to do is to test it and then make it do what you want. If you tell us a) what exactly it does and b) what you want it to do that's different we can probably help with that too.
Steve
