Topic: Blowing out the DAC? (Read 975 times) previous topic - next topic
cjdelphi
Quote
DuaneB
Dubai, UAE
Offline Offline
Edison Member
[applaud] 19
View Profile
WWW
Personal Message (Offline)
Re: How to you write to the second DAC?
« Reply #3 on: February 16, 2013, 05:21:04 PM »
   Bigger Bigger Smaller Smaller Reset Reset Reply with quoteQuote
Be careful with your second DAC Output, A lot of us are blowing out the DAC.
As most DACs will be connecting to amplifiers it would make sense to modify a future version of the board to include a series current limiting resistor to protect these two high value pins - high value as in there are only two of them andf or some, they are the main reason for buying a Due.
Duane B
rcarduino.blogspot.com
So then what kind of value resistor will protect the DAC ?  <1kohm?
DuaneB
Not sure why you have started you post with a random selection of my profile and a response from another thread.
The most relevant topic to your question is this one -
http://arduino.cc/forum/index.php/topic,139733.15.html
Have a look at the response towards then end of the post written by 'stimmer' - read it carefully because its based on another chip due to the limited information available on the actual chip used in the Due.
Duane B
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
