Topic: how to reduce the electrical noise (Read 9495 times) previous topic - next topic
paimpozhil
Hi MarkT,
Thanks for the answer,
To keep everything out of equation I disconnected all my PIRs and kept the arduino to the minimum.
I measured the voltage across the +5 and GND.. while the Flourascent light is flickering.
I saw voltage spikes upto 6 or 7 sometimes even more during this and hence the AtMega is restarting.. Is that possible?
Will atmega reboot when this happens?
I use the same wallwart to power the ULN2003 for  8 relays as well as the ATmega . will this cause Ground loop?
paimpozhil
I use a 7805 with 2x 470uF decoupling capacitors .. and I see more than 5V during the light flickers ..
Input is 12v from the wallwart which already has its own regulators. should i replace wallwart and try?
or should i change the voltage regulator IC to be something better than this?
paimpozhil
OK I have measured the voltage across my 12v wallwart lol it goes UPTO 35V during flickering.
I tried to replace my nokia phone charger and see what happens, it keeps its voltage stable..
I think the problem is my cheap crappy wallwart.. everyone agrees?
Grumpy_Mike
Yes it sounds like that is right. You could always get a zenner diode across the supply to try and clip any voltage spikes on the line.
