Topic: Trouble installing Arduino Due Programming Port (COM) on Windows vista (Read 2096 times) previous topic - next topic
nikhiljn540
Hello
I followed the instructions for installing this driver from http://arduino.cc/en/Guide/ArduinoDue
But the it does not get installed successfully. I get the following message:
Quote
Windows encountered a problem installing the driver software for your device
Windows found driver software for your device but encountered an error while attempting to install it.
A service installation section in this INF is invalid
Anyone else had a similar problem or knows of a possible solution?
Thanks
IAM_Carbon_Based
I had a similar issue, make sure you select the actual .inf file. that is what I had to do in order for the driver to install.
nikhiljn540
I did choose the correct .inf file.. Apparently it worked fine on Windows7 but giving trouble on Vista.
