Loading...
Pages: [1]   Go Down
Author Topic: Whack a mole project  (Read 309 times)
Offline Offline
Newbie
View Profile
Hi All,
I’m trying to make an electronic “whack a mole” game, basically a board of 9 light up push buttons, a button will light up at random and the player has to hit that illuminated push switch, this will put out the light and another random button will come on, repeat for 30 seconds and then display how many buttons were hit in time.
I’m pretty sure the Arduino will be a good platform for this but I have no idea what “illuminated push buttons” I’d need (ratings etc) or where to get them (I’m in the UK).
Really appreciate any advice on this project, I’ve not touched electronics since a (very) little bit at Uni and looking forward to getting back to it.
Matt
Logged
Offline Offline
God Member
View Profile
The most important rating is going to be how much abuse it can take. I would suggest looking at buttons designed for arcade use:
http://www.adafruit.com/products/1185
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
even heavier duty would be switches intended for childrens science parks.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
God Member
View Profile
Do you have a link to one? Google wasn't friendly with those search terms.
Logged
Offline Offline
Newbie
View Profile
Thanks guys, I found some big buttons on amazon but when I asked the seller if they'd work with something like an Arduino they said no as they needed much higher power than the arduino would supply. Would appreciate some guidance on all the bits I'll need to get this hooked up.
Thanks
Logged
Offline Offline
God Member
View Profile
The switch part shouldn't care, but the light probably does. What is "much higher?" If those switches end up being your best option, you will just have to look at methods to control a larger voltage for the lights. Not a big deal.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Post a link to that eBay page and we will have a look for you.
As you are in the UK have you tried Farnell?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Might these work?
https://www.sparkfun.com/products/11274
https://www.sparkfun.com/products/9181
Video demo:
http://www.youtube.com/watch?v=T1jdjmbe1mM&feature=youtu.be&t=2m38s
Lefty
Logged
Offline Offline
Newbie
View Profile
These are the buttons I found,
http://www.amazon.co.uk/gp/aw/d/B008MU3UM0/ref=aw_ls_6_7?colid=1BMFYA40O0HVQ&coliid=I1YX9COGUKRK1G
Appreciate any tips on how to wire this lot together.
Thanks
Logged
Offline Offline
God Member
View Profile
Ahh, 120V lamps in it. Not practical. The buttons that both retrolefty and I linked to would be pretty much the same, but a bit bigger and the lamp can be powered with a lower voltage. Note that they are the same, just different sources. It appears you must be in the UK, so you are better off finding a local source for them.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Where did you see that?
The title said Red LED switch
http://www.amazon.com/Amico-Round-Button-Switch-Arcade/dp/B008MU3UM0
I saw a lot on the ratings of the switch but nothing on the light. If it is an LED it is not going to be 120V.
The ratings of the switch only specify the maximum voltage and current not the minimum.
Logged
Offline Offline
Newbie
View Profile
Thanks Grumpy_mike, farnells a great website.
What do people think of these?
http://uk.farnell.com/cherry/kfb2ala2rbb/switch-pushbutton-spst-10a-250v/dp/1674427
Now I've found the arduino and the buttons what else will I need to get started? Apologies for all the questions but I'm a bit out of my depth here.
Also, how many of these switches could the arduino accept? I see its got 14 possible inputs but will these buttons take 1 for the led and 1 for the switch?
Thanks
« Last Edit: March 22, 2013, 03:27:07 pm by Parky86 » Logged
Offline Offline
God Member
View Profile
Since you will really only have one switch input at a time, I would use an 8-bit priority encoder (or more than one if you have more than 8 switches) such as the 74HC148. This will take the 8 inputs and reduce them to just three bits with the bonus of having a signal to let the arduino know that a switch was pressed. These can be cascaded to provide more than 8 inputs.
And for the LEDs, just do the opposite: use a 74HC138 which is a 3 to 8 demultiplexor. 3 signals will control 8 LEDs.
Together these reduce your pins from 16 to 8 (for 8 switches and 8 LEDs)
Logged
Pages: [1]   Go Up
Print
Jump to:
