Topic: Sensor Values (Read 419 times) previous topic - next topic
mvaughan19
Hello All
Im working with a stretch sensor here and im trying to attach a percentage value to the analog value. I have done this (only part of the code). the problem im having is it will print all of the values 10%-100% rather than only printing the current value. I know that i need to create a range or some type only i forget what that is called in computer language... basically i need to create
if(sensorValue >800 but below 804) than print out 0%, and so forth for the rest 10%-100%. i need to put this into all of my if statements so they are no longer true.
any thoughts on the best way to do this?
Code: [Select]
    if(sensorValue>800){ //You can change the number here to adjust the threshold.
      Serial.print("Straight - 0%");
    //10
    if(sensorValue>805){ //You can change the number here to adjust the threshold.
      Serial.print("Straight - 10%");
    //20
    if(sensorValue>810){ //You can change the number here to adjust the threshold.
      Serial.print("20%");
    //30
    if(sensorValue>815){ //You can change the number here to adjust the threshold.
      Serial.print("30%");
    //40
    if(sensorValue>820){ //You can change the number here to adjust the threshold.
      Serial.print("40%");
    //50
    if(sensorValue>825){ //You can change the number here to adjust the threshold.
      Serial.print("50%");
    //60
    if(sensorValue>830){ //You can change the number here to adjust the threshold.
      Serial.print("60%");
    //70
    if(sensorValue>835){ //You can change the number here to adjust the threshold.
      Serial.print("70%");
    //80
    if(sensorValue>840){ //You can change the number here to adjust the threshold.
      Serial.print("80%");
    //90
    if(sensorValue>845){ //You can change the number here to adjust the threshold.
      Serial.print("90%");
    //100
    if(sensorValue>850){ //You can change the number here to adjust the threshold.
      Serial.print("100%");
Thank you for your time.
spatula
The problem is that if your value is > 850 all the conditions will be true. You may change your code this way:
Code: [Select]
// longer, boring but unambiguous
if (sensorValue > 800 && sensorValue <= 805) { //You can change the number here to adjust the threshold.
else if (sensorValue > 805 && sensorValue <= 810) {
or this way:
Code: [Select]
// shorter, but depends on the right ordering of the ifs
if (sensorValue > 850) {
} else if (sensorValue > 845) {
} else if (sensorValue > 840) {
marco_c
Have you tried to use map()
Code: [Select]
percentage = map(variable, 800, 850, 0, 100);
of course, this assumes a linear relationship (ie, each value read from the analog port is 2% of full scale).
If you want to keep it a multiple of 10% then you could use
Code: [Select]
percentage = (percentage/10) * 10;
or
precentage -= (percentage % 10);
to eliminate the last digit.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
