Topic: Arduino Uno + Bluetooth module ,,, not working (Read 12503 times) previous topic - next topic
jo_2010
i need help with my project
i have arduino uno connected to this Bluetooth module
http://www.lctech-inc.com/Hardware/Detail.aspx?id=684fb223-1a23-4b83-8dbd-4d58c2b3c0cb
this is the code i tried
char incomingByte;  // incoming data
int  LED = 13;      // LED pin
  Serial.begin(9600); // initialization
  pinMode(LED, OUTPUT);
  Serial.println("Press 1 to LED ON or 0 to LED OFF...");
  if (Serial.available() > 0) {  // if the data came
    incomingByte = Serial.read(); // read byte
    if(incomingByte == '0') {
       digitalWrite(LED, LOW);  // if 1, switch LED Off
       Serial.println("LED OFF. Press 1 to LED ON!");  // print message
    if(incomingByte == '1') {
       digitalWrite(LED, HIGH); // if 0, switch LED on
       Serial.println("LED ON. Press 0 to LED OFF!");
iam using windows 8 ,,, i have the following problem :
the projects works fine while connecting the arduino via usb cable & the serial monitor works fine but when trying to connect via laptop bluetooth i got 2 serial ports " com 8 " for incoming ,,, "com 9" for outgoing & nothing happen ,,, i couldn't send or receive anything via the terminal
Nick_Pyner
Have paired the arduino with the laptop?
Do you see flashing lights on the bluetooth module, and if so, what is the frequency?
What terminal pprogramme are you using on the laptop?
jo_2010
yes i have paired the arduino with my laptop & it shows 2 serial ports for the bluetooth
the lights on the bluetooth are flashing ,,, if you mean by frequency the baud rate it is " 9600 "
the terminal program is tera term  http://ttssh2.sourceforge.jp/
Nick_Pyner
#3
Mar 21, 2013, 04:26 am Last Edit: Mar 21, 2013, 04:28 am by Nick_Pyner Reason: 1
No I meant the led on the module. A slow flash 1hz meant it was working. A much faster flash just meant the power was on and it was idling. I use RealTerm and 9600 bd was fine.
jo_2010
the led on the bluetooth are flashing slow after pairing with laptop but still nothing on terminal
ttttkk
can your phone pair with the bt module? if so, can you control the arduino by inputting command from smartphone bt terminal?  I personally have been working on this module for 2 days, finally figured out how it works.
technoboy2084
I have a similar problem with the same BT module.
When I try to pair it with my notebook (windows 8), the pair seems to be ok (because the led flash slow), but after few seconds, windows show an "offline" status (see attachment #1).
When I try to pair it with my smartphone (android 4.0.4, sony xperia u), the pair seems to be ok too, but when I try to connect with a terminal (blueterm), it show the error "unable to connect device". Same problem with amarino 2.0
any idea?
thank you
ttttkk
it is quite strange that with the same wiring and sketch, my bluetooth module works fine with my duemilanove, but not with the UNO. Then after days of digging, I found out that I have to use software serial library to get UNO and bluetooth to communicate, you can try if this work for you.
http://arduino.cc/en/Reference/SoftwareSerial
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
  Serial.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(4800);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
technoboy2084
Thank you, but I already use that sketch...
Communication between Arduino and BT module is fine, the problem is that for some reason I can't understand, the BT module can't connect successfully after pairing with another device (pc or smartphone).
Nick_Pyner
These things can be a bit flakey.
My Arduinos talk perfectly to my laptop via bluetooth. It is the only communication I have with them at the moment.
My dumbphone can pair with Arduino but cannot do anything.
My Android tablet with BlueTerm can pair with Arduino but cannot do anything. That is very disappointing. I have not persued this as my laptop is fine and hardly less convenient than a tablet, and the tablet is really junk.
My desktop can see my phone and my tablet but cannot see the Arduinos.
In short, all the problems lie with the peripherals, not Arduino.
I fail to see the need to use software serial library to get UNO and bluetooth to communicate. I don't think anybody else does. I only use bluetooth for data aquisition, but no extra software of any sort is required to do this.
technoboy2084
I use SoftwareSerial  so I can get 2 serial port: from arduino to pc with usb and the other one form arduino to BT module.
In that way, when I set BT module in command mode, I can send AT commands from pc to bt using arduino as proxy because I don't a FTDI cable.
technoboy2084
Now I can connect successfully from Windows 8! I achieved that installing Toshiba Bluetooth Stack from http://aps2.toshiba-tro.de/bluetooth/?page=download-toshiba (I read something about that somewhere on Internet).
But the problem is still present with my Android phone.
ttttkk
My UNO responses to BT only if i use the software serial library. I don't know why, but my duemilanove is okay without it. it's kind of strange.
technoboy2084
Eventually I solved my second problem: it's my idiot-phone (Sony Xperia U)! Please don't buy it, it's the worst android phone I've evere seen!!
The HC-05 connect successfully with Samsung S2 and S Advance, so I need to change my phone to accomplish my project...
