Loading...
Pages: [1]   Go Down
Author Topic: Accurate Pressure / Weight Scale needed...  (Read 462 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Long time lurker, first time poster...
Im starting a project for a weight scale.  I found the pressure sensors on sparkfun, (piezoresistive sensors), but what i am looking for is something that has a range from 0 - 30 lbs but I need it VERY VERY accurate...   were talking grams.
Of course I made the mistake of going to digikey and searching for piezoresistive sensors...  oh boy...    Well I am hoping someone out there knows more then I do and can help out...
thanks
tom
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
If you need accuracy, you probably want a "load cell".  Google it.
You might be able to calibrate your way to success with a piezo, but there are a lot of variables, like temperature that will have to be calibrated out.  Better to start with the right sensor.
Probably your biggest problem is that 30 lbs of grams is more than the 10 bit (cough) accuracy you can get from the ADC on the Arduino.  A lb is 453 grams, 30 lbs is  13,000+ grams.  That means you will need a more accurate ADC, specifically, 14 bits, and you will need to be very careful about noise.
I'd say that you will need a pretty good quality load cell, and you need a good analog engineer to design you a PCB that will get you a real 14 bits from the load cell.  Shielding will also be an issue.
It's definitely doable, just not easy.
Logged
Pages: [1]   Go Up
Print
Jump to:
