Topic: Dumb Dad needs homework help!!!!!!! (Read 547 times) previous topic - next topic
Pugsly
Mar 21, 2013, 12:22 am Last Edit: Mar 21, 2013, 12:26 am by Pugsly Reason: 1
OK heres the jist......  4th grade son needs to do an "invention".  what does he want to do? I see you tinkering with stuff all the time....How about a timer that counts down when I'm playing video games and than shuts off the TV?   WHOA, slow down.  Let me do some research first.
Many days later.........
How about we just do a countdown timer?  Sounds super simple right?
Well here is where i need help.  FAST (due tomorrow!!!!)
I have a http://nootropicdesign.com/digitshield/
which is actually just a 4 digit 7 segment display with the transistors and time shifters built in on a protoshield board.
I can easily get a countdown timer going with no problem, But 2 things.......
All i want to do is add:
1) a piezo buzzer at zero that buzzs for no longer than like 3 or 5 seconds   and
2) a button or switch so that when it gets to zero will reset back to given a total seconds
not anything that changes time or pauses or anything
Right now all it does is loop from 300 seconds to zero than back to 300 to zero again and again and again.
Heres the code so far  it already has the setup for the button and buzzer (I think)
I read all the tutorials on timer, tone, stopwatch, etc   HELP!!!!!!!
#include <DigitShield.h>
float counter = 0;
int d = 10;
const int buttonPin = 8;     // the number of the pushbutton pin
const int speakerOut = 9;
int buttonState = 0;         // variable for reading the pushbutton status
#define BUTTON 8
void setup(){
  pinMode(buttonPin, INPUT);
  pinMode(speakerOut, OUTPUT);
  DigitShield.begin();
  DigitShield.setPrecision(0);
  DigitShield.setValue(counter);
  counter = counter - .0001;
  if(counter <=0) {
    counter = 300;
grendle
can use a for loop for the soundmaker
spatula
Hi, can't you just do this?
boolean wait_for_button_pressed = false; // this flag controls whether the loop waits for a buttonpress to restart the counter
loop()
 if (wait_for_button_pressed) // if true, a timeout expired, to restart must press a button
   if (digitalRead(buttonPin) == HIGH) // do something only if a button has been pressed
     counter = 300; // reset the counter to the initial value
     wait_for_button_pressed = false; // proceed normally until the counter goes to 0 again
 else // normal condition
   if(counter <=0)
     tone(pin, frequency, duration); // with pin, frequency, duration to be defined
     wait_for_button_pressed = true; // set the flag so that next loops will check for buttonpress
I didn't try it so it may contain errors. It is not very accurate and it may miss a button press if released really fast, but it's simple and should work, quick. For the physical assignment of pins to buzzers and buttons refer to the library examples.
