Topic: Micro SD and LCD display (Read 959 times) previous topic - next topic
MillerJLee98579
i am trying to build a robot with 2 servo, 3 sensors, an lcd display and a micro sd breakout board for data logging. my problem is i am not sure how to connect both my display and sd card since the appear to use the same pins
Osgeld
same pins? as in...
if they are SPI there should be a enable pin for each device, turn on the one you want to talk to and your good
if they are i2c then the whole thing happens as an address request
MillerJLee98579
micro sd has these pins - 5v, 3v, GND, CLK, DO, D1, CS, CD
128x32 SPI OLED has these pins- GND, 3.3v, VIN, DATA, CLK, D/C< RST, CS
Osgeld
CS = chip select, they go to different outputs of the arduino to select which device your talking to
MillerJLee98579
so i would be able to tell the arduino which device is on what pin for chip select?
MillerJLee98579
and do i need a special shield for my i2c line sensor?
