Author Topic: Dataflash issues with Due  (Read 263 times)
Using 1.5.2 IDE with a Due.
Code won't compile:
#include <SPI.h>
#include <DataFlash.h>
I get these errors:
C:\Arduino\arduino-1.5.2\libraries\dataflash\DataFlash.cpp: In member function 'void DataFlash::setup(int8_t, int8_t, int8_t)':
C:\Arduino\arduino-1.5.2\libraries\dataflash\DataFlash.cpp:151: error: 'SPSR' was not declared in this scope
C:\Arduino\arduino-1.5.2\libraries\dataflash\DataFlash.cpp:151: error: 'SPI_2XCLOCK_MASK' was not declared in this scope
C:\Arduino\arduino-1.5.2\libraries\dataflash\DataFlash.cpp:152: error: 'SPCR' was not declared in this scope
C:\Arduino\arduino-1.5.2\libraries\dataflash\DataFlash.cpp: In member function 'void DataFlash::begin()':
C:\Arduino\arduino-1.5.2\libraries\dataflash\DataFlash.cpp:176: error: 'SPCR' was not declared in this scope
C:\Arduino\arduino-1.5.2\libraries\dataflash\DataFlash.cpp:177: error: 'SPSR' was not declared in this scope
Anyone successfully using this library with Due? Thanks for any help!
Manchester (England England)
Solder is electric glue
Libary link?
https://github.com/BlockoS/arduino-dataflash
« Last Edit: March 21, 2013, 12:26:09 pm by joshuaj » Logged
Thanks.
It seems to use the normal SPI library and the problem with that is that it is talking directly to the hardware registers of the processor. On the Due those registers are simply not present in the same location with the same bit meanings.
To further complecate the matter the Due's SPI pins are not on the same pins as a normal Arduino but are on a pin header, the one just above the Arduino Logo.
So the whole thing needs a bit of a rewrite I am afraid.  That is the problem with libraries that talk direct to hardware, when the hardware changes the rug is pulled from underneath it.
Thanks for looking at that Mike.
So I'm using the SPI library for other devices on the Due currently and that works. The 1.5.2 IDE takes into account weather you are using an AVR or SAM device and includes the proper library..  Dataflash includes SPI but the compiler does not find it so I #included it.. Seems like there's a linking problem but I don't have any expertise here..
Thanks!
Josh
I get
ataFlash_test.cpp:4:24: error: test/Dummy.h: No such file or directory
When I compile the sector erase example with 1.5.1
And the same when I try it with 1.0.3 for a Uno. I just think it is a rubbish piece of code.
