Topic: Can the arduino run a java application (Read 940 times) previous topic - next topic
lewisjoyce
Dear everyone,
At this moment in time im working on a project with the arduino.
And i want to run a java application on the arduino so it can talk to other devices running my java application?
is it possible to run a java applicaiton on the arduino itself?
Or do i have to say "connect it to a computer which runs a java application?
Would be great to get some information so my project can move forward
Kind Regards
Lewis
Lewis Joyce
Erdin
No.
The 'normal' Arduino boards run compiled code and can turn a led on and off and so. But communication with .NET is possible for some board and the new Arduino Due has more possibilities.
However, the Arduino can communicate with almost everything.
See the Playground section, http://playground.arduino.cc//Main/InterfacingWithHardware#Communication
How would you want to communicate between the Java applications ?
lewisjoyce
we are communicating with TCP messaging through java.
So im guessing we would have to have the java application on the computer itself.
Regards
Lewis Joyce
Lewis Joyce
sonnyyu
#3
Mar 21, 2013, 03:48 pm Last Edit: Mar 21, 2013, 03:55 pm by sonnyyu Reason: 1
u might try out processing (java base app)
http://playground.arduino.cc/interfacing/processing
if u like processing visual interface, then import your TCP messaging class into processing.  you are all set.
if u dislike processing visual interface or prefer headless (no visual interface at all), then import your processing class into yours.
Java's  "Write once, run anywhere" has pre-requirement condition;-  Java run time lib/JVM.
atmel/arduino chip (highend) does meet JVM (subset) requirement. i.e. avr javacard.
processing forum
java for 8/16 bits cpu/mpu
JAVA EMBEDDED
laadams85
If your other programs are running java you can have them communicate with the arduino through the serial com ports.
Alternatively you could probably have the arduino send TCP/IP packets over ethernet or possibly wifi.
http://arduino.cc/forum/index.php/topic,24085.0.html
This also looks interesting, TCP/IP over serial.
http://playground.arduino.cc/Code/SerialIP
Hopefully that will steer you in the right direction.
sonnyyu
One thing at Arduino site;-
use firmata communicate with processing+TCP messaging class.
Now you need wrote 0 line of code at Arduino.
0 line of code=100% bug free code.
firmata
