Malaysia
Offline
Full Member
Stay calm and call batman!
« on: March 21, 2013, 09:08:21 am » |
Hi, i have been Using an arduino UNO since early 2012. i recently purchased another 2 UNO, (looks slightly different in terms of the color of tactile switch and board color). when i upload a sketch to the OLD UNO, it works fine, but when i upload it to the newer UNOs with the same sketch, it runs for a while and stops working. however , every time i hit the reset button, it works for a while again. is there a particular reason for this? i heard someone said that the sketch might occupy too much memory, but when i checked, it only takes up about 5102 bytes. is it the fault of the new UNOs? is anyone else experiencing the same problem?
i notice the old bootloader has the number 1153 but the new says 1228. does it make a difference?
« Last Edit: March 21, 2013, 09:35:12 am by desmondttm123 »
Logged
California
Offline
God Member
« Reply #1 on: March 21, 2013, 10:35:23 am » |
Check the back of your UNO and look above the WWW.ARDUINO.CC to see if it says MADE IN ITALY or DESIGN IN ITALY. If it says DESIGN IN ITALY, it is a UNO clone made from the open source design sheets, but the parts could be inferior or the bootloader has the wrong fuse settings. If the vendor sold it as an Authentic Arduino, you can verify it here: http://arduino.cc/en/Main/Buy
Logged
Austin, TX
Offline
Faraday Member
CMiYC
« Reply #2 on: March 21, 2013, 11:23:26 am » |
Post clear pictures of your boards. When editing a post click on the "additional options" to add attachments.
Where did you buy them from?
Logged
Malaysia
Offline
Full Member
« Reply #3 on: March 21, 2013, 12:36:42 pm » |
Hi , i realize that i have to reduce the voltage of the power supply in order for it to work. i cannot use anything higher than 6v. both says made in Italy, i got it from an authorized reseller. ill post a picture of the two UNOs. The top one is the older UNO.
« Last Edit: March 21, 2013, 12:43:18 pm by desmondttm123 »
Logged
Malaysia
Offline
Full Member
« Reply #4 on: March 21, 2013, 12:44:11 pm » |
here is the back
Logged
California
Offline
God Member
« Reply #5 on: March 21, 2013, 01:00:08 pm » |
Those are more authentic than mine and mine came with the cute paper box  I think Arduino now silkscreens a batch number on the back for process control which my authentic does not have. It is quite odd that you need to use a 6VDC power supply. Do you have a DVM to peek at your voltages on the 5v0, 3v3 and Vin with the different power supplies?
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #6 on: March 21, 2013, 01:01:58 pm » |
If you swap the chips between the 2 boards, do you see the same stoppage?
Logged
BHZ, MG, Brazil
Offline
Sr. Member
Android developer; Arduino enthusiast
« Reply #7 on: March 21, 2013, 02:26:30 pm » |
You can always bootload the new UNOs with the newest bootloader, using the old UNO as an ISP. Do that from IDE 1.0.3 or newer. Then you switch and also burn a new bootloader in the old UNO.
Logged
Malaysia
Offline
Full Member
« Reply #8 on: March 22, 2013, 11:09:30 pm » |
hi, i have swapped the boot loader and the problem still happens...how do i burn new boot loader??
Logged
California
Offline
God Member
« Reply #9 on: March 23, 2013, 10:50:43 am » |
Logged
Malaysia
Offline
Full Member
« Reply #10 on: March 24, 2013, 11:17:38 am » |
Hi Thanks for your reply! and thanks for the advice=)
Logged
