Loading...
Pages: [1]   Go Down
Author Topic: Firmata confusing pins  (Read 101 times)
Offline Offline
Newbie
View Profile
I am using firmata with maxuino. My project has been working fine until now, pin 10 and 11 will not output a HIGH or LOW. I've yet to upload a sketch directly from the Arduino software to see if the Pins work while not being controller by firmata.
Has anyone had this problem or know why my pins all of a sudden are not responding?
Thanks
Logged
Offline Offline
Newbie
View Profile
I just test my pins 10 and 11 on a solenoid using this sketch
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  digitalWrite(9, HIGH);
  delay(1);
  delay(1);
And the pin won't even work for that. This code works for any other pin however. Maybe it is broken ?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
How you determining the pin "works"?  Unless you are using an oscilloscope,  I doubt a 1ms delay gives you the results you expect.
How much current do some solenoids draw?
Logged
www.cmiyc.com - A guide to being an Enginerd
Pages: [1]   Go Up
Print
Jump to:
