Topic: Timing the duration a test has been running (Read 2863 times) previous topic - next topic
DetroitTitan13
I am looking for the code or library that will allow me to start a timer that will time how long a test is true. For example, I want a timer to start and continue to run as long as the voltage < voltageValue in the first 'if' statement in the code below. Does anyone have any ideas how to do this?
Previously I have tried to do this with the millis(), but since my project will be running for hours at a time, with the voltages changing at irregular intervals, the numbers that the board will have to store will become extremely large. Is there some other way to do what I want to do?
note: start Timing (t); is just a place holder. This is where I want my timer to begin timing.
if (voltage<voltageValue){
    start Timing (t);
    if ((voltage < voltageValue) && (t > Tup))  // has been up for more than 30 seconds
      stop Timing (t);
      Action = 0;
      goto Reset;    // Reset
    else if ((voltage > voltageValue) && (t < Tup))  // has sat down before 30 seconds
      stop Timing (t);
      Tdown = t * 30;              // changes up time to new value
      goto beginning ;         //goes to 'beginning' of do loop
retrolefty
Millis() is the proper 'tool' to use. You don't need to store each unique elapsed times separably, just keep adding the elapsed time the test was true into a single accumulated total time.
Lefty
robtillaart
Check my stopwatch class - http://playground.arduino.cc/Code/StopWatchClass - could do the job.
Rob Tillaart
DetroitTitan13
Here is a project that I am trying to complete that needs to be able to record the time lapsed that a test has been running. I have utilized a delay (1000) and a counter t++ as a makeshift timer. Will anyone out there please take a look at this code and let me know what they think. The compiler says that this code checks out, but when I hoop up my arduino board, piezo buzzer, and pressure sensor the system is not doing of these activities. Where is my problem????
  pinMode(9, OUTPUT);  // Piezo Buzzer
void loop ()
  int counter = 0;
Reset:
  int sensorValue = analogRead(A0);        // reads value from force sensor located in A0
  int voltage = sensorValue * (5.0 / 1023.0);  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  int voltageValue = 2.0;      // sets the pressure limit, so that when pressure is higher than this value considered "high pressure" sets threshold for high and low
  int Tup=30000;                  // Initial Tup is 30 sec
  int Tdown=900000;              // Initial Tdown is 15 min (900 sec)
  int Action;             // When action == 1 carry out the do loop
  int t=0;                // Time counter
  if (voltage >= voltageValue) {
    Action=1;
    Serial.println(voltage);      // print out voltage
    do{
beginning:
      delay (1000);        // start Timing (t);
      if ((voltage> voltageValue) && (t > Tdown)) // has been sitting for 15 minutes
        digitalWrite(9,HIGH); // Buzzer goes off for 3 seconds;
        delay (3000);
        digitalWrite(9,LOW);
        if (voltage > voltageValue){
          counter++; // Count missed times
          Action = 0;
        goto Relief;                     // Relief function
      else if ((voltage<voltageValue) && (t < Tdown))  // has gotten up before 15 minutes is up
        Tup = t / 30;                // changes Tup value for next test in Relief function
        t = 0;
      t++;                          // time counter increases by 1
    while(Action=1);
Relief:
    while (voltage<voltageValue){
        t = 0;                   // resets time counter
        Action = 0;              // will not return to do loop
      t++;                        // increase time counter by 1
robtillaart
The usage of the goto statement is considered bad programming because it corrupts heaps and stacks the computer uses to keep its internal administration.
int Tdown=900000;
will overflow the int as the max value an int can hold is 32767.
use long as type
What can be useful is to introduce functions that do part of the work. At the highest level you get something like
  float voltage = readVoltage();  // hides all the A0 and converting
  if (doAction1() == true)
    doRelief();
bool doAction1()
  if (...) return false;
  return true;
void doRelief()
  return;
Hope this helps to get you rewriten your code
Rob Tillaart
