Topic: RFID Again! (Read 12834 times) previous topic - next topic
SubMicro
Ok I've officially gone mad!
My project is simply this....
RFID reader to scan tags
3X4 keypad for user input upon RFID failure
16X4 LCD for feedback
electric door latch or lock which ever I get my hands on first
Ok user swipes card or key fob, scanner sends data to Arduino
which compares data to database, if a match, opens or unlocks door . If RFID tag fails user inputs code using keypad and LCD.  After X number of failures system locks out for X amount of time. Records all activity in log on SD / MMC Card or I2C Eprom etc.. Possibly add intercom if possible.
Do I use If Else statements to compare RFID strings?
How do I implement a database?
Should I get a Sanguino or Mega Arduino for this?
And will Batman escape the Jokers devious trap??
Will Robin come out of the closet????
Stay tuned for this and more!! Muwa ha ha ha ha!
Told ya I went Mad! [smiley=2vrolijk_08.gif]
SubMicro
SubMicro
Electronics newbie
Home Machinist
PaulS
How many RFID tags/cards will be given out? If it's a small number, you don't need a database. You could have a file on the SD that contains the valid numbers. Read the file looking for the number. If it's found, open the door.
If it's a large number, you might need a database. Of course, stuffing a database onto an Arduino is like parking a semi in a compact spot.
You're not attaching enough stuff to max out an Arduino. It's capable of all you want to do. Well, except the database, and that won't fit on a Mega, either.
Of course Batman will escape. Wouldn't be able to make another pointless movie and a bazillion bucks if he didn't.  >:(
I thought Robin was out of the closet. ;)
I'm not sure I'm ready for more.
SubMicro
#2
Nov 28, 2009, 12:55 am Last Edit: Nov 28, 2009, 01:37 am by SubMicro Reason: 1
Just a small number of tags will be issued 5 at max. I think using part of your code will work
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
//create a Serial object RFID
SoftwareSerial RFID = SoftwareSerial(rxPin, txPin);
char code[20];
int val = 0;
int bytesread = 0;
char Red[]    = "3900A502C35D";     // Tag ID.
char Blue[]   = "39009F2DAD26";    // Tag ID.
char Yellow[] = "39005082A843";    // Tag ID.
char Card1[]  = "140029A6079C";   //  etc..
char Card2[]  = "14002943BFC1";  //   etc..
int ledCnt = 5;
int LED[] = {13, 11, 9, 7, 5};
 Serial.begin(9600); //open serial hardware
 RFID.begin(9600); //open serial software
 pinMode(rxPin, INPUT); //set pin on arduino for receiving RFID data
 pinMode(txPin, OUTPUT); //this is not important
 for(int i=0; i<ledCnt; i++)
   pinMode(LED[i], OUTPUT);
 val = 0;
 bytesread = 0;
 while(bytesread < 12)
   // read 12 digit code
   val = RFID.read();
   if(val == 3)
   { // if header or stop bytes before the 10 digit reading
     break; // stop reading
   if(val != 2)
     code[bytesread] = val; // add the digit
     bytesread++; // ready to read next digit
     code[bytesread] = '\0'; // add the NULL
 if(bytesread >= 12)
 { // if 12 digit read is complete
   Serial.print("Tag: [");
   for(int i=0; i<bytesread; i++)
     Serial.print(code[i]);
   Serial.println("]"); //print the whole 13 bytes
   int tag = FindValidTag(code);
   Serial.print("Tag number: ");
   Serial.println(tag);
     digitalWrite(LED[i], LOW);
   if(tag > 0 && tag <= ledCnt)
     digitalWrite(LED[tag-1], HIGH);
int FindValidTag(char *code)
 if(strcmp(code, Red) == 0)
   return 1;
 else if(strcmp(code, Blue) == 0)
   return 2;
 else if(strcmp(code, Yellow) == 0)
   return 3;
 else if(strcmp(code, Card1) == 0)
   return 4;
 else if(strcmp(code, Card2) == 0)
   return 5;
   return 0;
However how to modify this to include the keypad, LCD, and triggering a relay instead of LED's is what I'm working on now.
How can I eliminate the LED's and just pull one pin high on a matched read regardless of the number? I also need to be able to manually enter a code and pull a pin high to energize a relay module I have to power the electric door latch.
SubMicro
Electronics newbie
Home Machinist
PaulS
Triggering the relay should be exactly the same as lighting an LED, except that you want to trigger the relay when any valid tag is presented, instead of lighting a specific LED.
Depending on which LCD and which keypad you have, there may be libraries that make communicating with them simple. Getting the logic right should be the only hard part. And that isn't even too difficult. Start with comments, without code, that describe what you want to do. Then add code that does what the comments say.
If you have difficulties, post you code, and we'll help.
SubMicro
Thanx I appreciate the help. I really like your suggestion of adding comments first then adding code to do what the comments say, great idea. :D
I'm afraid of breaking the code i'm not sure what I can remove of the LED prt of the code.
SubMicro
Electronics newbie
Home Machinist
PaulS
Make a copy of the code, before making changes. When the changes work, save them.
The LED code is this:
int ledCnt = 5;
That code defines the number of LEDs to be manipulated and the pins that the LEDs are connected to.
That code declares the LED pins to be output pins.
and:
That code turns off all the LED pins, and turns on one LED pin, depending on which tag was read.
SubMicro
#6
Nov 28, 2009, 06:54 pm Last Edit: Nov 28, 2009, 06:57 pm by SubMicro Reason: 1
Here's what I did to use only one pin to go high with a good read.
int ledCnt = 5;
 int LED[] = {5};
Heres what I added to turn the pin low after enuff time to open the door.
       delay(5000);
       digitalWrite(LED[tag-1], LOW);
Woo Hoo!!! it works!
I know it's not pretty but it works, now I'm working on the keypad which will be much more difficult!
Thank you for letting me turn your code into a mess ;) and helping me understand it.
Any tips as where to insert the keypad code??
SubMicro
Electronics newbie
Home Machinist
SubMicro
#7
Nov 28, 2009, 08:20 pm Last Edit: Nov 28, 2009, 08:56 pm by SubMicro Reason: 1
Ok it doesn't work!  The LED only lights for one tag! I know it's just an ID10T problem, I'm working on it.
got now had to change this line
int LED[] = {5};
to this
int LED[] = {5, 5, 5, 5, 5};
SubMicro
Electronics newbie
Home Machinist
PaulS
Simpler would have been to change
int LED[] = {5};
to
int LED = 5;
and change:
       delay(5000);
to:
   digitalWrite(LED, LOW);
     digitalWrite(LED, HIGH);
   delay(5000);
SubMicro
I tried something similar but couldn't get it to work, then I tried your changes. I had to change one other line from
to
pinMode(LED, OUTPUT);
but after that worked like a charm. My problem was that, tag-1 couldn't figure it out!
Now I'm on hold untill I figure out the pin out for the keypad! my DVM is on the fritz. (cheap Harbor Freight crud) I need to invest in a decent DVM.
I'm through for the night, all the wires are blurring together! time for a break!
SubMicro
Electronics newbie
Home Machinist
SubMicro
Ok PaulS
Now that I've got the keypad wired up and functional, where in the code should the keypad code go?? My thought is at the beginning.
start up, check for keypad input if so do this, check for tag input if so do this, loop
What do ya think?
SubMicro
Electronics newbie
Home Machinist
PaulS
SubMicro
I just thought of something, the keypad used up all my digital I/O pins. The LCD has nowhere to go!
SubMicro
Electronics newbie
Home Machinist
PaulS
Time for a Mega. Or, the analog pins can also be used as digital pins 14 thru 19.
SubMicro
Which is better Arduino Mega or Sanguino??
The Mega has way more I/O's
http://www.wulfden.org/TheShoppe/freeduino/sanguino.shtml
SubMicro
Electronics newbie
Home Machinist
