Topic: Need help with a Boolean operation and simplification on LED Keypad (Read 907 times) previous topic - next topic
Rich_P
Hi All, i am contructing a CAN based keypad for a motorsport vehicle,
Currently i am merging some code to read a keypad and switch on a corresponding LED above it
I am having trouble with the Boolean "i" ststement as it requires 2 pushes of a keypad to extinguish or illuminate an led, if the same operation has been perfomed on a diffrerent key
I understand why it is doing it, as it needs to switch from i = 1 to i = 0 before it can switch an LED on again, i just cant seem to get my head round doing it, also i would like to simplify it a little but not sure how.
Hope you are able to help
Many thanks
Rich
#include <Keypad.h> // Include Keypad library
#include <Ucs1903.h> // Include LED Controller Library
#define NUM_LEDS 4  // Defines Number of LED's
#define PIN 13      // Defines Data Pin for LED's
Ucs1903 ledStrip(PIN, NUM_LEDS);
boolean i = 0; //Defines Switch State
int j = 0;   // Variable to Define which LED to Switch
const byte ROWS = 5; //defines number of rows
const byte COLS = 3; //defines number of columns
char keys[ROWS][COLS] = {  //define the symbols on the buttons of the keypads as an array
 {'1','2','3'},
 {'4','5','6'},
 {'7','8','9'},
 {'0','A','B'},
 {'C','D','E'},
byte rowPins[ROWS] = {9, 8, 7, 6, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {12, 11, 10,}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
keypad.addEventListener(keypadEvent); //Listen for a keypad Press
void loop(){
 char key = keypad.getKey();
 if (key) {
    if (i==1){
 ledStrip.setLed(j, 0, 0, 75);  // Turn on LED if Putton has been Pressed
   ledStrip.setLed(j, 0, 0, 0);   // Else Turn LED Off
   ledStrip.show();   // Send Data to LED Controller
void keypadEvent(KeypadEvent key){         //What to do when a particular Key is pressed
 switch (keypad.getState()){
   case PRESSED:
     switch (key){
       case '1':  i = !i, j= 0; break;
       case '2':  i = !i, j= 1; break;
       case '3':  i = !i, j= 2; break;
       case '4':  i = !i, j= 3; break;
       case '5':  break;
       case '6':  break;
       case '7':  break;
       case '8':  break;
       case '9':  break;
   break;
robtillaart
your indenting makes the program very hard to read. Then you miss code flaws like
  if (key) {
if a key is pressed do nothing otherwise nothing. Probably not what you meant
Reformat your code so it better reflect the structure you want. TIP use CTRL-T to auto format your code in the IDE.
Rob Tillaart
