Topic: [LIB] Interrupt driven DHT11 Lib (idDHT11) (Read 70234 times) previous topic - next topic
niesteszeck
Mar 22, 2013, 03:51 pm Last Edit: Mar 22, 2013, 09:11 pm by niesteszeck Reason: 1
Hello, I'm working with DuinOS and the DHT11 library has some problems working with it 'cause the timing. 'cause of this i had improved the library to use ineterrupts on pins and liberate the cpu meanwhile. I have proved it in a Mega2560 with arduino 1.03 and is working bery well.
You can get this lib at
https://github.com/niesteszeck/idDHT11
robtillaart
#1
Mar 22, 2013, 07:58 pm Last Edit: Mar 22, 2013, 08:00 pm by robtillaart Reason: 1
Looks good!
I can see only one remark that is STOPPED is with double P ;)
I'll make a link in the playground article - http://playground.arduino.cc/Main/DHT11Lib - to this thread so people can find it easier!
(done)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
niesteszeck
Sorry for that (I speek spanish as my native language)
Now is corrected
robtillaart
Rob Tillaart
chuckiecc
Hi can someone help please with newb question.  Trying to read temp/rh with the dht11.  In the code samples and examples I came across a VERY cool code example that not only reads temp/rh BUT reads dewpoint calcs.  Which is very useful for me.  Only problem is that being a NEWB Im sure that Im doing something wrong in loading the code to the Arduino.
Arduino Mega 2560
Mega shield
So code that has information I want is here-
http://playground.arduino.cc//Main/DHT11Lib?action=sourceblock&num=1
but when I try to compile/upload, i get the error message "DHT11 does NOT have a name"  ARRGGHH....
now I notice that along with this code there are two other files
one labeled
dht11.h (code is here http://playground.arduino.cc//Main/DHT11Lib?action=sourceblock&num=2)
the other labeled
dht11.cpp (code is here http://playground.arduino.cc//Main/DHT11Lib?action=sourceblock&num=3)
so not sure (because I am a newb) if these are necessary? help define the name of the DHT or what..
Can someone help please..
thanks again for your patience in advance..
niesteszeck
Hello, your question isn't related to this specific lib. You are using example code and source files from the original DHT11 lib. THIS lib that I published here is another version, that works different (interrupt driven way) and has his own example codes. If you want you can try it downloading it from the link to github in the original post of this thread.
robtillaart
@niesteszeck
Can this DHT22 patch be included in the library?   - http://forum.arduino.cc/index.php?topic=175356.0 -
imho it is worth the effort to merge!
Rob Tillaart
niesteszeck
I'm talking on the other thread. If the modification is working on a dht22 sensor, I'll analyze how to mix both sensors in the same library, other way we have to make 2 libraries. Other thing is that I dont have a dht22 sensor, so any modification must be proved by others (or someone can gift me one :D)
robtillaart
#8
Jul 03, 2013, 08:51 pm Last Edit: Jul 03, 2013, 08:53 pm by robtillaart Reason: 1
It should be quite easy to add DHT22 support into one library
- add a flag that indicates the type and select the right - bits to data -  function in the end.
the code in the other thread looks good to me, so I think you can start designing/integrating to create a first beta.
Rob Tillaart
niesteszeck
Yes sure, but the modification to DATA section on the interrupt that is proposed on http://forum.arduino.cc/index.php?topic=175356.0 I need to confirm that is actually working to integrate into the other library.
robtillaart
Or you can build it into the lib and you have something to be verified by someone.
Rob Tillaart
niesteszeck
That's right. I'll make it for DHT22 to, but give me some time to do it, I'm working and don't have to much time to my personal projects, so please be patient. I'm goig to continue this conversation on the other thread
Tero521
Is it possible to use multiple dht11 sensors with this library?
The test so far only reports -7 for second sensor.
niesteszeck
#13
Mar 21, 2014, 09:01 pm Last Edit: Mar 21, 2014, 09:22 pm by niesteszeck Reason: 1
I'm not pretty sure if it's working with two sensors, but I have two, and when I was developing it I used the 2. If I'm not wrong it should work with two sensors. The only thing is that you have to use 2 different pins that has interrupts
In a quick review, I can say that looks like the interrupt is not being called. What method are you calling to get the -7 value, can you share the code.
A small example that is based on the example that comes with the lib:
Code: [Select]
 Board          int.0  int.1  int.2  int.3  int.4  int.5
Uno, Ethernet  2  3
Mega2560  2  3  21  20  19  18
Leonardo  3  2  0  1
Due          (any pin, more info http://arduino.cc/en/Reference/AttachInterrupt)
#include <idDHT11.h>
int idDHT11pinA = 2; //Digital pin for comunications
int idDHT11intNumberB = 0; //interrupt number (must be the one that use the previus defined pin (see table above)
int idDHT11pinB = 3; //Digital pin for comunications
int idDHT11intNumberB = 1; //interrupt number (must be the one that use the previus defined pin (see table above)
//declaration
void dht11_wrapperA(); // must be declared before the lib initialization
//declaration
void dht11_wrapperB(); // must be declared before the lib initialization
// Lib instantiate
idDHT11 DHT11A(idDHT11pinA,idDHT11intNumberA,dht11_wrapperA);
idDHT11 DHT11B(idDHT11pinB,idDHT11intNumberB,dht11_wrapperB);
// This wrapper is in charge of calling
// mus be defined like this for the lib work
void dht11_wrapperA() {
 DHT11A.isrCallback();
void dht11_wrapperB() {
 DHT11B.isrCallback();
if you test this small example (need to be completed the loop and setup functions), please tell me how it goes. If it works, you can make a pull request to add an example that use 2 sensors on github, so everyone wins. If not, we can review why and analyze if it will be possible and add this functionality to the lib, anyway, everyone wins :).
Tero521
#14
Mar 23, 2014, 12:34 pm Last Edit: Mar 23, 2014, 08:12 pm by Tero521 Reason: 1
Sorry for the long wait, i was swamped by another aspect of my project.
Now it's working. The problem was the missing
Code: [Select]
DHT11B.acquire();
Is there any other reason than debugging purpose for this part of code?
Code: [Select]
while (DHT11A.acquiring())
 int result = DHT11A.getStatus();
 switch (result)
   case IDDHTLIB_OK:
     Serial.println("OK");
   case IDDHTLIB_ERROR_CHECKSUM:
     Serial.println("Error\n\r\tChecksum error");
   case IDDHTLIB_ERROR_ISR_TIMEOUT:
     Serial.println("Error\n\r\tISR Time out error");
   case IDDHTLIB_ERROR_RESPONSE_TIMEOUT:
     Serial.println("Error\n\r\tResponse time out error");
   case IDDHTLIB_ERROR_DATA_TIMEOUT:
     Serial.println("Error\n\r\tData time out error");
   case IDDHTLIB_ERROR_ACQUIRING:
     Serial.println("Error\n\r\tAcquiring");
   case IDDHTLIB_ERROR_DELTA:
     Serial.println("Error\n\r\tDelta time to small");
   case IDDHTLIB_ERROR_NOTSTARTED:
     Serial.println("Error\n\r\tNot started");
   default:
     Serial.println("Unknown error");
because it work just fine without it, and i didn't figured out how to change it for the second sensor.
Here is the modified code. Sorry for the bad formating  :smiley-red:
Code: [Select]
Uno, Ethernet  2  3
Leonardo  3  2  0  1
int idDHT11intNumberA = 0; //interrupt number (must be the one that use the previus defined pin (see table above)
//declaration
//declaration
// Lib instantiate
idDHT11 DHT11A(idDHT11pinA, idDHT11intNumberA, dht11_wrapperA);
idDHT11 DHT11B(idDHT11pinB, idDHT11intNumberB, dht11_wrapperB);
 Serial.println("idDHT11 Example program for two sensors");
 Serial.print("LIB version: ");
 Serial.println(IDDHT11LIB_VERSION);
 Serial.println("---------------");
 Serial.print("\nRetrieving information from sensors: ");
 Serial.print("Read sensor: ");
 //delay(100);
 DHT11B.acquire();
 DHT11A.acquire();
 switch (result)
   case IDDHTLIB_OK:
   default:
 Serial.println("************************************************************");
 Serial.println("*********************************Sensor 1*******************");
 Serial.print("Humidity (%): ");
 Serial.println(DHT11A.getHumidity(), 2);
 Serial.print("Temperature (oC): ");
 Serial.println(DHT11A.getCelsius(), 2);
 Serial.print("Temperature (oF): ");
 Serial.println(DHT11A.getFahrenheit(), 2);
 Serial.print("Temperature (K): ");
 Serial.println(DHT11A.getKelvin(), 2);
 Serial.print("Dew Point (oC): ");
 Serial.println(DHT11A.getDewPoint());
 Serial.print("Dew Point Slow (oC): ");
 Serial.println(DHT11A.getDewPointSlow());
 Serial.println("*********************************Sensor 2*******************");
 Serial.println(DHT11B.getHumidity(), 2);
 Serial.println(DHT11B.getCelsius(), 2);
 Serial.println(DHT11B.getFahrenheit(), 2);
 Serial.println(DHT11B.getKelvin(), 2);
 Serial.println(DHT11B.getDewPoint());
 Serial.println(DHT11B.getDewPointSlow());
 delay(2000);
