Topic: [LIB] Interrupt driven DHT11 Lib (idDHT11) (Read 69007 times) previous topic - next topic
niesteszeck
I've added an example that use 2 sensor, please try it at
https://github.com/niesteszeck/idDHT11/tree/master/examples/idDHT11_Lib_2sensors_example
One problem with your example is that it doesn't check if the B sensor end acquiring. so maybe sometimes you could get error values.
The part that you said is for debugging, is only to know which error was causing a problem. you can erase it, but you should do something like this to be sure you receive a good measure
Code: [Select]
while (DHT11A.acquiring()) // check if first sensor has ended acquiring
int result = DHT11A.getStatus();
if(result != IDDHTLIB_OK)
   //HANDLE THE ERROR
   // DO WHATEVER YOU WANT with the data of the sensor
Tero521
petoulachi
#17
Dec 04, 2015, 09:33 am Last Edit: Dec 04, 2015, 09:41 am by petoulachi
Hello,
I'm trying to use idDHTLib with a DHT22 on a Pro 5V, using port 3 on the Pro (and therefore interrupt number 1).
But I cannot read any value, everytime I've got a CheckSum error.
Any idea of what I'm doing wrong ?
Regards,
edit : ok my very bad, I do not noticed I had to change the callback method. Sorry !
miltonortega
buenos dias,
cordial saludo serian tan amables de ayudarmen en este error que me sale al cargar el programa.
soy novato o nuevo en este campo.
sketch_may27a.ino:17:17: fatal error: DHT.h: No such file or directory
compilation terminated.
Error de compilaciĆ³n
gracias    david
markfrencken
Hi, very nice library.
I would like to make an addition to catch a transmission timeout while recieving a talagram, for example due to a bad connection (dupont wires anyone):
   FILE:       idDHT11.cpp
   VERSION:    0.1
   PURPOSE:    Interrupt driven Lib for DHT11 with Arduino.
   LICENCE:   GPL v3 (http://www.gnu.org/licenses/gpl.html)
   DATASHEET: http://www.micro4you.com/files/sensor/DHT11.pdf
   Based on DHT11 library: http://playground.arduino.cc/Main/DHT11Lib
#include "idDHT11.h"
#define DEBUG_IDDHT11
idDHT11::idDHT11(int pin, int intNumber,void (*callback_wrapper)()) {
   init(pin, intNumber,callback_wrapper);
void idDHT11::init(int pin, int intNumber, void (*callback_wrapper) ()) {
   this->intNumber = intNumber;
   this->pin = pin;
   this->isrCallback_wrapper = callback_wrapper;
   hum = 0;
   temp = 0;
   pinMode(pin, OUTPUT);
   digitalWrite(pin, HIGH);
   state = STOPPED;
   status = IDDHTLIB_ERROR_NOTSTARTED;
int idDHT11::acquire() {
   if (state == STOPPED || state == ACQUIRED) {
      //set the state machine for interruptions analisis of the signal
      state = RESPONSE;
      // EMPTY BUFFER and vars
      for (int i=0; i< 5; i++) bits = 0;
      cnt = 7;
      idx = 0;
      hum = 0;
      temp = 0;
      // REQUEST SAMPLE
      digitalWrite(pin, LOW);
      delay(18);
      delayMicroseconds(40);
      pinMode(pin, INPUT);
      // Analize the data in an interrupt
      us = micros();
      us_global = us;
      attachInterrupt(intNumber,isrCallback_wrapper,FALLING);
      return IDDHTLIB_ACQUIRING;
   } else
      return IDDHTLIB_ERROR_ACQUIRING;
int idDHT11::acquireAndWait() {
   acquire();
   while(acquiring())
   return getStatus();
void idDHT11::isrCallback() {
   int newUs = micros();
   int delta = (newUs-us);
   us = newUs;
   if (delta>6000) {
      status = IDDHTLIB_ERROR_ISR_TIMEOUT;
      state = STOPPED;
      detachInterrupt(intNumber);
      return;
   switch(state) {
      case RESPONSE:
         if(delta<25){
            us -= delta;
            break; //do nothing, it started the response signal
         } if(125<delta && delta<190) {
            state = DATA;
            status = IDDHTLIB_ERROR_RESPONSE_TIMEOUT;
            state = STOPPED;
      case DATA:
         if(delta<10) {
            status = IDDHTLIB_ERROR_DELTA;
            state = STOPPED;
         } else if(60<delta && delta<155) { //valid in timing
            if(delta>90) //is a one
               bits[idx] |= (1 << cnt);
            if (cnt == 0) {  // whe have fullfilled the byte, go to next
                  cnt = 7;    // restart at MSB
                  if(idx++ == 4) {      // go to next byte, if whe have got 5 bytes stop.
                     // WRITE TO RIGHT VARS
                     // as bits[1] and bits[3] are allways zero they are omitted in formulas.
                     hum    = bits[0];
                     temp = bits[2];
                     uint8_t sum = bits[0] + bits[2];
                     if (bits[4] != sum) {
                        status = IDDHTLIB_ERROR_CHECKSUM;
                        state = STOPPED;
                        status = IDDHTLIB_OK;
                        state = ACQUIRED;
            } else cnt--;
            status = IDDHTLIB_ERROR_DATA_TIMEOUT;
            state = STOPPED;
      default:
bool idDHT11::acquiring() {
   if (state != ACQUIRED && state != STOPPED)
      if (newUs-us_global>6000)
          state = STOPPED;
           return false;
          return true;
       return false;
int idDHT11::getStatus() {
   return status;
float idDHT11::getCelsius() {
   IDDHT11_CHECK_STATE;
   return temp;
float idDHT11::getHumidity() {
   return hum;
float idDHT11::getFahrenheit() {
   return temp * 1.8 + 32;
float idDHT11::getKelvin() {
   return temp + 273.15;
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double idDHT11::getDewPoint() {
   double a = 17.271;
   double b = 237.7;
   double temp_ = (a * (double) temp) / (b + (double) temp) + log( (double) hum/100);
   double Td = (b * temp_) / (a - temp_);
   return Td;
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double idDHT11::getDewPointSlow() {
   double A0= 373.15/(273.15 + (double) temp);
   double SUM = -7.90298 * (A0-1);
   SUM += 5.02808 * log10(A0);
   SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
   SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
   SUM += log10(1013.246);
   double VP = pow(10, SUM-3) * (double) hum;
   double T = log(VP/0.61078);   // temp var
   return (241.88 * T) / (17.558-T);
// EOF
Flixon
#20
Nov 25, 2017, 01:33 pm Last Edit: Nov 25, 2017, 02:53 pm by Flixon
Hello everybody, i am working on my project and i want use your library there. But i am newbie in this so i don't understand how this interrupt in your example code is working. I thought it's nothing more needed just arduino + sensor DHT11. when i want test your code for one sensor it only shows me what is on this picture https://imgur.com/a/RT7I9. And nothing more happens. It looks like it's waiting for interupt on that interrupt port. I tested all reccomended interrupt ports and still not working. Can you please explain me how your example code working ? Thank you very much :)
