Topic: How to read the Tinkerkit Inputs? Missing docs... (Read 11115 times) previous topic - next topic
RickBullotta
analogread()?  If so, what are the analog I/O positions that map to these connectors (A0-AX)?
Thanks.
TheKitty
This article shows you how to read the Tinkerkit inputs:
http://21stdigitalhome.blogspot.com/2013/03/reading-arduino-esplora-tinkerkit-inputs.html
The IN-A is set to +5V and IN-B set to ground via jumpers
At the end of the article, it gives an overview of the Tinkerkit outputs - they are directly mapped to PWM pins 11 and 3 so they are easier programatically to use.
I hope this helps others use their Esplora in the time before the team releases revised code to officially use these features.
Mike - http://21stdigitalhome.blogspot.com/
RickBullotta
TheKitty
Glad I could help and I learned a couple of things in the process.
mpsufi
Always a techie...
