Topic: MPU6050 library and Arduino Due (Read 3574 times) previous topic - next topic
afrancescon
Hi all,
I need more pin than Uno has to build my project: for this reason I thought to buy an Arduino Due board.
I would prefer the Due instead the Mega in order to have a powerfull board.
Before buy it I would check that I will have no problem to make my components works on Due so would be nice
if you can help me to understand this.
MPU6050 from Sparkfun (https://www.sparkfun.com/products/11028). From datasheet it seems no problem
to work at 3.3V, right? I want to use it with the Jeff Rowberg's library: they will work on Due?
For other component (like PING))) sensor) that works at 5V I was suggested to use this logic level converter (https://www.sparkfun.com/products/8745): is it ok for this goal?
whitewater
There are two aspect you need to take into account:
1. Hardware compatibility (voltage level): here there is no problem. MPU6050 work with DUE. Just connect the VDD and VIO to 3.3V.
2. Software (CPU) compatibility. I had to copy this code: http://arduino.cc/forum/index.php/topic,129407.msg976225.html#msg976225 to MPU6050.h to get the library working with DUE.
afrancescon
Hi whitewater,
thanks for your reply: my Due board is arriving, I will try it!
Thanks
Alessandro
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
