Topic: calculate resistor (Read 671 times) previous topic - next topic
kmkn
I connect my arduino to a flowmeter sensor, with multimeter i got i=12miliamp v=4.2volts (without any resistor). As the sensor output is 4-20miliamps, and arduino limit is 5volts, how should I add a resistor so that I could capture all?
Thanks
retrolefty
"Two wire 4-20ma current loops" require an external DC power supply to provide the loop voltage, 24vdc is the most common supply voltage used but 12vdc will work for most 'transmitters' using that method. So wire the +12vdc to the sensor's positive lead and wire the sensor's negative lead to a 250 ohm resistor and the other end of the resistor wires to the 12 vdc negative terminal. Now add a wire from the 12vdc negative terminal to an arduino ground pin and finally add a wire from the non-grounded end of the 250 ohm resistor to an arduino analog input pin. The sensor will cause the arduino to see a 1 to 5vdc measurement value corresponding to a sensor 0% to 100% flow value.
Lefty
kmkn
For powering the arduino I am using the normal power adapter.
So my wire will come from the sensor output positive, negative and ground
Thank you for the reply.
runaway_pancake
#3
Mar 25, 2013, 03:36 am Last Edit: Mar 25, 2013, 04:07 am by Runaway Pancake Reason: 1
5V / 0.02A = 250?
current loop current : voltage across resistor, to Arduino Analog In pin
but
something makes me want to buffer that (LM358)
[Maybe it's those infrared hot dogs I ate?]
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
mjkzz
Here are some basic stuff from National Instruments (English)
http://www.ni.com/white-paper/6940/en
www.mjkzz.com
www.pylin.com
kmkn
I think it is a 4 wire, and powered by transmitter ...so how? thanks
