Topic: How Do I Run Two Motors Same Time WIth Arduino Motor Shied R3 (Read 1 time) previous topic - next topic
adruinouno111
Mar 23, 2013, 01:22 am Last Edit: Mar 23, 2013, 02:45 am by adruinouno111 Reason: 1
How Do I Run Two Motors Same Time WIth Arduino Motor Shied R3? Can I See Code Please.
Adruino Mega
Thank You
JimboZA
It's explained here...
You just need to set pins 12 and 13 for motor A and B direction, and PWM pins 3 and 11 for their speed.
ZS6JMB
adruinouno111
Can You Provide Me With Sample Code I Tried It But Only One Motor Works.
JimboZA
Why don't you rather post your code so far and perhaps a pic of the circuitry....  then we can help you get it fixed, rather than do it for you  8)
ZS6JMB
adruinouno111
int E1 = 3;
int M1 = 12;
int E2 = 11;
int M2 = 13;
    pinMode(M1, OUTPUT);
    pinMode(M2, OUTPUT);
    digitalWrite(M1,LOW);
    digitalWrite(M2, LOW);
    digitalWrite(E2, HIGH);
    digitalWrite(E1, HIGH);
    delay(5000);
adruinouno111
It lights up both A and B lights but all i hear is humming?
Using 9V Battery Motors Are Each 3V
baselsw
int E1 = 3;
int M1 = 12;
int E2 = 11;
int M2 = 13;
    delay(5000);
Please use the code quotes next time... Anyway I can directly see that you didn't define the pins of E1 and E2 as outputs.. Try this to begin with:
int E1 = 3;
int M1 = 12;
int E2 = 11;
int M2 = 13;
    pinMode(E1, OUTPUT);
    pinMode(E2, OUTPUT);
    delay(5000);
adruinouno111
[SOLVED] I Had To Get A 4 AA Battery Pack For The Motor Shield.
