Topic: Logic gates without transistors? (Read 8552 times) previous topic - next topic
cjdelphi
Mar 23, 2013, 04:02 am Last Edit: Mar 23, 2013, 06:44 am by cjdelphi Reason: 1
i don't see how both diodes either and being triggered would not pull high to low? both diodes would do the same? i don't get how AND is made?
Osgeld
#1
Mar 23, 2013, 05:10 am Last Edit: Mar 23, 2013, 05:12 am by Osgeld Reason: 1
I cant see what your talking about but
if 4 or 5 is low, then current is sinked thus logic = low
if both are high then current sinks though 1, thus logic = high
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
retrolefty
#2
Mar 23, 2013, 05:16 am Last Edit: Mar 23, 2013, 05:19 am by retrolefty Reason: 1
Are you referring to the classic wired-AND gate using two diodes and a resistor pull-up?
http://upload.wikimedia.org/wikipedia/commons/thumb/9/9d/WiredAND.svg/220px-WiredAND.svg.png
Two high inputs equal a high output, either (or both) inputs low equals a low output, that statisfies the classic AND truth table.
Then you can contrast that with the classic wired-OR gate:
http://upload.wikimedia.org/wikipedia/en/8/82/WiredOR.JPG
Lefty
cjdelphi
Sorry, the image was not showing....  what's going on with those 2 diodes and pull up, so there's always 9v high ...
I would presume either not both but either of the diodes would pull it ground? not both like an AND logic calculation
retrolefty
You don't seem to understand how a truth table works. Just map out the four possible input voltage combinations (low-low, low-high, high-low, high-high) that are possible and the resulting voltage output for each of the conditions and see if you can't spot the AND function after all.
Lefty
cjdelphi
#5
Mar 23, 2013, 07:00 am Last Edit: Mar 23, 2013, 07:09 am by CrossRoads Reason: 1
[path deleted - seems to have been hijacked by a semi-porn site - Moderator]
if pin 11 and pin 14 are low (B and C of the binary output)
Reset triggers, but i don't understand why this circuit ONLY triggers off when both B and C are LOW, i don't understand
why would it not tigger off if B was low and C was high? B would provide a low signal to trigger reset?  how's the AND part
to this circuit working via the 2 diodes and a pull up?
CrossRoads
But it is an AND.  Look at the truth table:
In1  In2   Out
0     0       0
0     1       0
1     0       0
1     1       1
Thus Wired AND - both inputs must be High for output to be High.
If Both needed to be High to make the output Low, that would be a NAND -  if you were to take that output and invert it using a NPN collector follower,
In1  In2   Out
0     0       1
0     1       1
1     0       1
1     1       0
And there's Wired OR, with diodes flipped around - either input High makes outpt High:
In1  In2   Out
0     0       0
0     1       1
1     0       1
1     1       1
If you were that output and invert it using a NPN collector follower, then you have NOR:
In1  In2   Out
0     0       1
0     1       0
1     0       0
1     1       0
In all cases, the diode serve to isolate the inputs from each other.
If either but not both were to affect the output, that would be Exclsive OR, XOR:
In1  In2   Out
0     0       0
0     1       1
1     0       1
1     1       0
XOR/XNOR more difficult to pulloff with just diodes & resistors tho.
and inverted, XNOR
In1  In2   Out
0     0       1
0     1       0
1     0       0
1     1       1
Generally, Wired OR and  Wired AND are all that's needed - if any of several inputs go low, the output goes low - such as with a keypad, pressing any key to Gnd can be used to create an interrupt and tell the code to go scan the keypad.
If you want action only with 1 or the other, that's easier to mimic in software - similar example, with multiple keys pressed, scan the inputs, if more than 1 was pressed, ignore the result.
oric_dan
For historical reference, the diagram in reply #2 is probably about the very first AND
gate ever invented. Since you can't make a very good computer that way [ie, it loses
noise margin after about 3 gates in series], they added an NPN inverter to it's output,
and invented the modern computer world, starting from there.
http://www.google.com/search?&site=imghp&tbm=isch&source=hp&biw=1033&bih=858&q=diode+transistor+logic
Osgeld
yes, you can only do rather simple things with diode logic (though its fun to mess with)
westfw
Which came first, diode logic or relay logic?
Osgeld
I would guess relay as it was introduced into practical application about 60 years before the diode (in practical application)
graynomad
I had a calculator once that was entirely diode logic, there must have been 1000s of them plus some magnetic core memory as well and to top it off a nixie display.
I hope I've still got it somewhere.
As for relay logic, we built an entire runway lighting system using relay logic, flip flops, NAND, AND, OR gates etc were each a large PCB. All at 48V IIRC.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
runaway_pancake
http://www.thocp.net/biographies/shannon_claude.htm
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
oric_dan
Yeah, I knew someone would bring this up, ;-).
krupski
That diagram reminds me of the logic gates used in the Apollo Guidance Computer.....
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
