Topic: combine vars ? (Read 638 times) previous topic - next topic
Slee_The_Sloth
i need to combine two vars. but not add them together. any i
deas?
Thanks for your time.
JimboZA
any ideas?
No, because I don't know what you mean....
Maybe if you show an example?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
pYro_65
More info is needed, but here is a guess:
You maybe want two integers stored together, a simple bit shift might do.
uint8_t A;
uint8_t B;
uint16_t C =( A << 8 ) | B;
Forum Mod anyone?
https://arduino.land/Moduino/
Slee_The_Sloth
i have a 12 chanel remote conected to my arduino. i found out i need more the 12 buttons to do all the things i need to do. so i was thinking thar i could use a var to catch the input. that works great for 1-9 but how to hande double digets? i cant add them up becuse, say i whated function 23. if input 1 = 2 and input 2 = 3 and u add them input1 + input3 it will = 5 i need to combinde them so i get a value of 23.
UKHeliBob
Seeing your code would help.
What do the other 3 buttons send ?
pYro_65
If your numbers are decimal ( base 10 ),
then simply:
#define BASE 10
int A = 2;
int B = 3;
int C = A * BASE + B;
Forum Mod anyone?
PeterH
You could either put the values in an array (one element per switch) or store them as bits in an integer big enough to hold all of them (the standard types give you 8, 16, 32, 64 bits to choose from).
The array would be easier to access but take more space, which would only be an issue if you are short of memory or need to send these values over a communications link at high speed.
