Topic: HOW to connect servo motor to arduino with l293d (Read 5927 times) previous topic - next topic
lironaharon
Mar 23, 2013, 11:36 am Last Edit: Mar 23, 2013, 11:58 am by lironaharon Reason: 1
Hi
I'm trying to figure out how to build the electronic circuit of arduino + servo + l293d
I found an example of an electrical circuit  of a regular DC motor
If someone could give me an explanation or a link
Thanks
JimboZA
Have a look at this tutorial.
You don't need a 293... just hook the servo red and black to a power supply of suitable voltage (usually 5-6), and the yellow to the Arduino pin used in the sketch (9 as it stands), and also hook the motor black to the Arduino ground.
(Tutorial shows servo power hooked to the Arduino... that's not recommended, best to use a separate supply.)
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
lironaharon
#2
Mar 23, 2013, 11:54 am Last Edit: Mar 23, 2013, 11:57 am by lironaharon Reason: 1
Thank you
  I know how to make a simple connection of the servo
For my project I need to figure out how to make the connection with L293D and arduino and a separate  power supply
JimboZA
I'm not sure if that's feasible....
The 293 does two main things:
  • It switches a dc or stepper motor's relatively high (say 12+) voltage with a logic level voltage (5)... that's unnecessary on a servo, since the high voltage goes straight into the servo in the first place and doesn't need switching
  • It provides direction to the dc or stepper motor by controlling which motor input is  + or -... that's also unnecessary on a servo, because that's basically what the pulse on the yellow line does.
If you have a look at a 293 data sheet, it makes no mention of using it to drive a servo- it mentions dc and steppers as specific purposes, though
scottyjr
What is the physical goal of your project? What are you attempting to do? - Scotty
JimboZA
Yeah, good question... perhaps the 293 / servo thing is a constraint imposed by a school / college project spec?
Or maybe the OP is confusing servos and steppers?
lironaharon
Thanks guys
I really do not need this part to operate Servo
Sorry
