Topic: digitalWrite following analogWrite (Read 928 times) previous topic - next topic
freeze
I am new to the Due. Here is my question:
The following code blinks an LED using the Uno board, but not with the Due.
int led = 9;
  pinMode(led, OUTPUT);
  analogWrite(led, 220);
  digitalWrite(led, LOW);
However, the following works with both boards:
int led = 9;
  analogWrite(led, 0);
Does the Due not allow a call to digitalWrite if analogWrite has already been called?
freeze
The reason I ask this question is that such behavior is not only non-intuitive, but also breaks many lines of useful existing code. See the attachment for an example of motor driving code (for the Solarbotics Brutusbot robot) that works for the Uno board, but not for the Due board.
I have modified the robot code successfully. But this behavior of the analogWrite() and digitalWrite() seems to be a serious problem that should be addressed.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
